BigJimnyMeet 2024
Re:Gen 4 reversing camera
- SmallBlue
- Visitor
01 May 2019 18:34 #207074
by SmallBlue
Gen 4 reversing camera was created by SmallBlue
Hello I’ve seen a reversing camera online, can anyone that has fitted a camera tell me if the head unit accepts the red and yellow plugs. Or is it a special fitment? And does the unit and camera detect you are in reverse via the canbus wiring? Thanks
- Thank you received: 479
01 May 2019 18:41 #207075
Replied by Soeley on topic Gen 4 reversing camera
Have a look
HERE
I fitted my own.
- SmallBlue
- Visitor
01 May 2019 19:04 #207076
by SmallBlue
Replied by SmallBlue on topic Gen 4 reversing camera
Thanks for your reply , is the camera you fitted the official Suzuki one (as it seems awfully overpriced) or an aftermarket one. And have you any photos of the install location. Also how does the surround come off the stereo? Thanks
01 May 2019 20:32 #207085
It is the genuine Suzuki camera. If you look under the rear bumper above the number plate, there is a hole blanked off between the number plate lights, that is where it fits. Head unit removal is simple, remove the trim underneath (between vents and screen), it just pulls off, you'll feel the joint on the bottom edge with your finger nails. Once that is off it will reveal two screws, remove them and just pull the head unit towards you, it is clipped in so will need slight persuasion to get it going. The only tool needed is a cross-head screwdriver.
The following user(s) said Thank You: SmallBlue, stiffsteve204me
- SmallBlue
- Visitor
03 May 2019 18:28 #207217
by SmallBlue
Another question Soeley if I may , the original camera does it just wire into the head unit or do you have to wire into the reverse lights as well. I’m really struggling to justify buying the original as it’s way way over priced. I’m looking to buy a similar size camera and an extra loom that has the all impo green plug that goes into the head unit. My Vw t5 has canbus wiring and that picks up when vehicle is put into reverse so no need for a wire to reverse lights.
03 May 2019 20:22 #207235
Yes, it just plugs into the head unit. I guess the reversing light connection is already built in.
- SmallBlue
- Visitor
04 May 2019 07:34 #207263
by SmallBlue
Replied by SmallBlue on topic Gen 4 Reversing Camera
George C I am not prepared to pay £235 for a camera that is worth around £20. I am trying to gather information to enable me to fit a camera at a sensible price. Go on have a look at their after market brochure it’s a joke the prices they are charging for tat.
- Thank you received: 1761
04 May 2019 08:27 #207269
Replied by Lambert on topic Gen 4 Reversing Camera
I have to take issue with that, sorry. Fitting a cheap after market unknown device into the electronics of a new car is a false economy. As suggested by George it invalidates the warranty on as a minimum the systems it is patched into and more widely gives the company the opportunity to wriggle out of other potential problems. It also immediately devalues the vehicle because who knows how badly it has been installed and again in a wider sense what else has been done on the cheap. It would definitely reflect in an offer of purchase if I were making one on such a car. Like I said earlier if it were a Mercedes Benz and a reverse camera was going to be a grand plus fitting I would not bother with it but at sub 300 quid that I in keeping with the price point of the car as a whole and not excessive in any way.
The following user(s) said Thank You: GeorgeC
- SmallBlue
- Visitor
04 May 2019 10:07 #207278
by SmallBlue
Take issue with whatever you fancy, I’m talking about a reversing camera not a cam belt or other major part. The “Suzuki” official one is probably made in the same factory as most others. We are talking about a length of wire and a camera even if you go for a kenwood /alpine it’s only around £100, not even a chance in hell its worth £235. I never skimp on my vehicles I have 3 and a motorcycle. If you think with ALL Oe equipment is good value for money then you are mistaken.
04 May 2019 11:01 #207280
No offense taken . What I saying is that if you fit a spurious electronic device that fails and takes other systems with it, that in turn costs you hundreds or possibly thousands of your pounds to rectify yourself it suddenly makes the initial saving over a genuine part covered by warranty seem inconsequential.
- Thank you received: 584
04 May 2019 11:25 - 04 May 2019 11:27 #207281
by facade
Replied by facade on topic Gen 4 Reversing Camera
I've looked at this already.
It appears that the Suzuki infotainment system is another of the cheap units knocked out by Bosch (Ask anyone with a Nissan Connect how reliable they are, and how expensive to fix- most go in the bin and are replaced with a Pioneer head unit for less money)
As such, the camera is one of those odd ones that run off 6V and is NOT a standard PAL composite one. (I don't know whether this just means it is NTSC or if there is some obscure encoding used)
It might be worth getting one of these
car-solutions.com/en/camera-connection-c...-of-2012-2019-my.php
and giving it a go with a £7 NTSC cheapie off eBay
(If you get one, get one for me too, I'll give you the $12)
Otherwise I did find this article which might help
www.team-bhp.com/forum/diy-do-yourself/1...-cross-1-6-zeta.html
I have to say that I'm a bit with Lambert, in that there is enough electronics to go wrong expensively, without giving Suzuki the chance to claim that my £7 camera caused the ABS system to go wrong, (which is why I'm paying stupid money for Suzuki to supply & fit the towbar & electrics, then any corrosion or electrical issues are down to them) but as regards theConnect SDLA unit, the guarantee will only be 12 months on audio gear (unless Suzuki are stupid) so I'd be inclined to try it and remove it all again if the car needed warranty work.
Last edit: 04 May 2019 11:27 by facade.
- CC Baxter
- Visitor
04 May 2019 12:47 #207283
by CC Baxter
Replied by CC Baxter on topic Gen 4 Reversing Camera
I fitted a cheap camera to a Toyota pick-up and it worked very well. I remember I had to splice a relayed feed from the reverse lights but it was fairly straight forward. I was assured at the time that all small reverse cameras were made in China including the Kenwood item I was considering at the time.
I think your viewpoint shifts with age, today if I wanted the camera I'd pay the £235 and save all the hassle.
