OBD1 OR OBD2 code reader for this vin
- Thank you received: 651
Didn't want castor bushes and it's still on a 2" lift for now
YOU might need adjustable pan hard rods after your lift
- Thank you received: 82
Tuning the welder is the first trick. The second trick is the copper spoon. Also using transit front bonnet for repair metal .
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
- Thank you received: 551
Also thanks for the tip. Copper spoon, made me Google and what a great idea. Going to make one to add to my welding kit.
Glad to help delighted me self with the copper spoon works a treat.Scimike wrote: Good work Dirtbird, nice green touch the repurposed Ford Transit.
Starting to go under the body now. Getting ready to take off the front axel and do a proper clean up replacing bushes at the moment. This Jimny only has 41 k on it and so far most components seem to be ok. Think I got to it in time .
- Thank you received: 923
- HG0606
- Visitor
HG0606 wrote: The silver jimny in the picture above is mine !!! Fame at last... If you want to know anything about it let me know...
This one? =
This one? =
This has to have a name ie stealth or subdued if you get what I mean. All the capability in a discrete cover if that makes any sense. Really like it thanks for the offer HG0606. Mighty.
