BigJimnyMeet 2024
Wheels and tyres
- Visitor
15 Jan 2019 21:07 #200821
Replied by Daniel30 on topic Wheels and tyres
The part of the nut that holds the wheel is flatter for the steel wheels I had to change mine after the tyre fitter mentioned it can't remember where I got mine, but Martin might be able to get a set
- Cremator1
- Visitor
16 Jan 2019 05:48 #200844
by Cremator1
Replied by Cremator1 on topic Wheels and tyres
Hi guys ok so I do need new wheel nuts then should I just search for steel wheel nuts will the ones I got on there be ok for now
- Thank you received: 1759
16 Jan 2019 06:45 #200846
Replied by Lambert on topic Wheels and tyres
As long as you get some ordered asap and use the car sparingly a few days wouldn't be a problem unless you are involved in a collision then you will have a problem.
- Cremator1
- Visitor
16 Jan 2019 06:54 #200847
by Cremator1
Hi lambert searched but can’t seem to find any they all look like the ones I have already
16 Jan 2019 07:05 #200848
Send James j999pre on here a message he will probably have a second hand set or alternatively Martin mlines should be able to get new ones.
- Cremator1
- Visitor
16 Jan 2019 07:07 - 16 Jan 2019 07:09 #200850
by Cremator1
Ok would sooner new ones why can’t I seem to find them they must be on eBay but they all look the same to me would like black ones to match the rims
Last edit: 16 Jan 2019 07:09 by Cremator1.
16 Jan 2019 07:31 #200852
Ok basic principles. Jimny has m12x1.25 wheel studs, very common and easy to find. Jimny ally wheels have a 60 degree mounting face or chamfer. If you have bought aftermarket wheels that also have a 60degree mounting face then that is good. The ally wheels are a thicker flange than the steel wheel so less thread protrudes allowing the factory closed or dome nuts to tighten to the wheel before the thread reaches the top of the nut. On the steel wheel there's a chance to tighten the nut to the correct torque but have the thread tight against the top of the nut therefore not correctly holding the wheel. This is not a problem with open ended nuts. Then there's the problem of the nut not sitting correctly if the wheel doesn't have a 60degree mounting face, which being aftermarket is a definite possibility.
The following user(s) said Thank You: Gadget
- Cremator1
- Visitor
16 Jan 2019 08:41 #200856
by Cremator1
Ok see what you mean so what degree but do I need as the shamfer on the nuts I have don’t seem to sit all the way in the rim hole
- Cremator1
- Visitor
16 Jan 2019 09:20 #200858
by Cremator1
16 Jan 2019 09:30 #200859
Without measuring it with a protracter which is easier with the wheel off Idon't know, it might not even be a chamfer as radius nuts are common too.
16 Jan 2019 09:32 #200860
Do you have the listing for where you bought them that should say what style of nut they use?
- Cremator1
- Visitor
16 Jan 2019 10:15 #200864
by Cremator1
Just had a look but does not say
