Re:isuzu 1.5td 4ec1 engine conversion
- Thank you received: 1
www.bigjimny.com/index.php/forum?view=topic&catid=6&id=62480
- Thank you received: 1754
I've just got the clutch hydraulics to bleed up and give the brakes an overhaul then should be good to go..........to an MOT and find out all the things that are wrong with it! One of them being king pins and rust in the rear of the body
They are held by magnetism. The vacuum is just used to move them.Jefferies wrote: I haven't but i like the idea of the viscous coupling. I took one of my front hub covers off the other day as i was always under the impression that the vacuum system was required not only to engage the hubs but also to keep them engaged. To my amazement i found that this isn't the case, and the vacuum is only there for the initial engagement/disengagement. So as far as i can tell if the hubs are in the locked position they will stay there (as i've removed the vacuum system).
