Forum
Suzuki Jimny
Jimny Chat
Bad condensation on inside of windows in cold weather.
BigJimnyMeet 2024
Thank you received: 728
31 Dec 2017 13:34 #187931
by kirkynut
Hold your breath!
Seriously though, think how small the Jimny is inside and how much glass it has. It stands to reason it will steam up. Lack of use doesn't help as said above.
Thank you received: 332
02 Jan 2018 11:38 #187964
1. Wind deflectors and a small gap in the windows helps!
2. Plastic container with silica gel crystals (?) (moisture collector refill bag) inside car under front seats. I used a plastic container with a tight lid that i drilled 12mm holes in the top. cannot spill unless flipped upside down.
3. Newspapers under the floor mats that you regularly swap for dry ones
4. if possible put a fan oven inside the car from time to time during winter. lift mats so it gets dry underneath as well.
(beware the fire hazards)
I would like suggestions of how to get more airflow on the windsheild with the defroster fan. I think it is way too weak.
Thank you received: 260
02 Jan 2018 18:08 #187973
yakuza wrote: I would like suggestions of how to get more airflow on the windsheild with the defroster fan. I think it is way too weak.
Buy a supplementary 12v window demister
Do it right - use Hammerite
When the blue light is flashing I am kidding.
Lambert
Offline
Moderator
The quickest Jimny in Harrogate...(that I own)
Thank you received: 1761
02 Jan 2018 19:57 #187976
If you have air conditioning that dries the windows very quickly, mine gets as much use in winter for demist as ever it does in summer for the heat.
03 Jan 2018 06:32 #187988
Seriously?
Those things are totally useless.
Forum
Suzuki Jimny
Jimny Chat
Time to create page: 0.115 seconds
