Big trip in the Jimny - what to take?
- emu88
- Visitor
One thing I am unsure about are my drive and power steering belts. As far as I and the PO know they are the ones fitted from factory (2004 with 78000 on the clock). I understand they are high mileage things but since I'm heading out on a long journey I wondered if I should either change them OR just keep a spare of each in the car. If one fails on a journey can they be replaced roadside in under an hour with the radiator still in and just some basic tools?
Thanks in advance!
- Visitor
- emu88
- Visitor
Right. I've seen the how to on changing them but it's a tad confusing.. Is it a one day job and at novice level?Daniel30 wrote: I would change them before I went, sods law is that they brake somewhere REALLY inconvenient and take a spare set
And this might sound retarded, but the 'drive' belt is the same as a cam belt yes?
- Visitor
- emu88
- Visitor
Makes sense yes, I'll look all over for cracks in the rubber. Have you had your kingpins changed yet?Daniel30 wrote: Pass on that emu88 I'm no mechanic depends how conveident you are I had mine changed as they looked ok on the top but badly cracked underneath the belt if that makes sense
- Visitor
- emu88
- Visitor
- jim
- Visitor
- emu88
- Visitor
Indeed I do plan to do that but it's just if one goes I need to know it's a possible shortish by-the-road job.jim wrote: I got my two belts from bigjimny shop. If you give him your reg Martin will make sure you get the right ones. Mine were both genuine suzuki. Most later jimnys are chain cam belts the other belts I believe are an auxiliary belt and a drive belt. Even if you don't fit them leave them in the boot and if one does go you'll have the correct belt ready.
Martin has told me the exact belts I need - drive belt, power steering belt.
Not looked into cam belt or timing belt. Are there a total of 4 belts then? I can only see 2!
- Visitor
emu88 wrote:
Ahh. I realise now you're not the chap who said he would be changing his soon and I was welcome to come and see how it was done! I can't remember who it was!Daniel30 wrote: Yeah not long after I bought the jimny only one side though the other side was fine
On page 3 of your 'kingpin bearing thread ' minibbb said he was changing them soon
- emu88
- Visitor
