× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
jimny tracking with bigger tyres. where?
  • jimnybob
  • Visitor
  • Visitor
12 May 2013 21:49 #70581 by jimnybob
I replaced my track rod ends last week and need my tracking doing now. Took it to kick fit, national tyres and formula tyres and non of them would do it, apparently the wheel size makes it impossible? Where does everyone get theirs done? I feel they were talking bullsh1t or is this true? I'm running 31" tyres with 30mm spacers. Thanks in advance :)
  • supergaz
  • Visitor
  • Visitor
12 May 2013 22:34 #70584 by supergaz
Replied by supergaz on topic jimny tracking with bigger tyres. where?
Best just to fit smaller tyres just to get the tracking done, they are also talking bullsh1t, this is coming from a GARAGE EQUIPMENT ENGINEER!.
  • jimnybob
  • Visitor
  • Visitor
13 May 2013 07:13 #70591 by jimnybob
Replied by jimnybob on topic jimny tracking with bigger tyres. where?
I'm thinking of taking it to a private garage and getting it done the old way with gauges. They were also trying to tell me that I needed 4 wheel alinement and all my castor angles changing. Smaller tyres wouldn't be a bad idea if I had a spare set. Thanks for your reply
  • markyp2000
  • Visitor
  • Visitor
13 May 2013 09:56 #70604 by markyp2000
Replied by markyp2000 on topic jimny tracking with bigger tyres. where?
There fobbing you off cos the tracking is a pain in the butt due to having 4 adjustments i did mine the other week took me a good hour as it was so far out i kept having to take the bars off to adjust each joint on its own
4 wheel alinement is so the stearing wheel is set straight
you can get front and rear wheel tracking done seperate
  • supergaz
  • Visitor
  • Visitor
13 May 2013 16:15 #70618 by supergaz
I'd love to know how they will adjust your castor angles!
I've never seen a mechanic yet that knows how to correctly do wheel alignment. Or even lift a car on a 2 post lift correctly/safely
I'm not digging at you Mark! I'd bring my Jimny to you if you were local!
  • reaper
  • Visitor
  • Visitor
13 May 2013 16:43 #70623 by reaper
Replied by reaper on topic jimny tracking with bigger tyres. where?
Bit to far for you but i take mine to a local tyre fitter , great set of lads and most of them off-road
Laser tracking no problems
www.wingerworthtyres.co.uk/
  • jimnybob
  • Visitor
  • Visitor
13 May 2013 19:17 #70635 by jimnybob
Thanks for all the replies guys :) took it to a local garage and they did it for 30 quid. Much better then it was, in that I can now just about do 35 without coming off the road :p got really bad death wobble! Not sure why though :(
  • markyp2000
  • Visitor
  • Visitor
13 May 2013 19:31 #70639 by markyp2000
I had wheel wobble but no play in king pins when i went to replace the half shaft seal i found the lower bearing was shot
  • vitara_mad
  • Visitor
  • Visitor
14 May 2013 10:19 #70668 by vitara_mad
Replied by vitara_mad on topic jimny tracking with bigger tyres. where?
get the wheels balanced if you not already had them done
  • jimnybob
  • Visitor
  • Visitor
14 May 2013 18:09 #70691 by jimnybob
markyp2000 wrote: I had wheel wobble but no play in king pins when i went to replace the half shaft seal i found the lower bearing was shot
where would I find the lower bearing?
  • jimnybob
  • Visitor
  • Visitor
14 May 2013 18:12 #70692 by jimnybob
vitara_mad wrote: get the wheels balanced if you not already had them done
who can I get to balance them? The place I took it to for tracking said 31" tyres won't fit in most tyre balancers. Should I take them to a lorry depot? Cheers
  • Dave cc
  • Visitor
  • Visitor
14 May 2013 18:21 #70693 by Dave cc
Replied by Dave cc on topic jimny tracking with bigger tyres. where?
markyp2000 wrote: There fobbing you off cos the tracking is a pain in the butt due to having 4 adjustments i did mine the other week took me a good hour as it was so far out i kept having to take the bars off to adjust each joint on its own
How do you track the back wheels on a jimny then ?
Time to create page: 0.104 seconds
Powered by Kunena Forum
