BigJimnyMeet 2024
- Thank you received: 1761
16 May 2021 15:14 #235101
Replied by Lambert on topic Re:Re:Re:Re:Dave's la(te)st buggy build...
Bookface is not for everyone and doesn't do much to deter idiots.
- Thank you received: 923
16 May 2021 20:21 - 16 May 2021 20:23 #235127
Replied by X8GGY on topic Re:Re:Re:Re:Dave's la(te)st buggy build...
Just remembered... when I popped round to see the lads working on the buggy -
I remember noticing that the rear engine / gearbox mount had delaminated, under the sill bar on the ramp in the above photo!, so I've just ordered one...
From the BigJimny store of course! - www.bigjimny.com/store/engine-mount-rear...ox-mount-type-1.html
A(nother) job for Wednesday then...?
Last edit: 16 May 2021 20:23 by X8GGY.
17 May 2021 07:13 #235135
I forgot (was embarrassed) to say, I’ve cried off rejoining the group for their first trip after lockdown is eased, this Sunday, as I’ve still got a couple of things to sort out on the buggy, and having only got it back on Friday after the clutch and gearbox were swapped, I’m not confident in it, or personally, to have a full days greenlaning in it just yet...
So I’m going to have a few more local trips both on and off road to make sure we’re both ready... me and the Boogie.
It looks like a wet week too...
17 May 2021 16:40 #235154
Replied by Riccy on topic Re:Re:Re:Re:Dave's la(te)st buggy build...
I hope your coming for at least the brekky meet mate? I want a look at the buggy!
Teething troubles are to be expected. Ulysses has been non stop tinkering for the entire time I've had it, Your coming to the end of it now as there's not much else left that hasn't been fettled now
18 May 2021 08:43 #235167
I’ll be there...
18 May 2021 08:48 #235169
The bits have started arriving...
Intake / idle control cleaner...
Also need to check where I removed the vacuum hub gubbins that I haven’t left a pipe loose to the atmosphere...
Both are to try and solve the fast idle issue...
(Although it would help to keep the pies warm?!)
18 May 2021 09:08 #235171
Ooh carbie cleaner I've lost many a happy hour to that evil smelling junk in the past!
18 May 2021 19:09 - 18 May 2021 19:14 #235184
Update post
removed, as after a test drive it was still idling @ 2,000rpm... more work tomorrow...
Last edit: 18 May 2021 19:14 by X8GGY.
18 May 2021 23:06 #235188
by LM42
Replied by LM42 on topic Re:Re:Re:Re:Dave's la(te)st buggy build...
try ( if you haven't) unplugging one at a time, each of the sensors around the throttle body and running the car, if its rough but stable its that sensor
i had a hunting/stalling issue, unplugged the TPS and it was rough but stable
if you have done all of this, ignore me!
19 May 2021 16:10 - 19 May 2021 16:15 #235209
Fixed as best I can for now (more photos later tonight) but made it out laning, and more importantly made it home again...
Some photos for now -
All taken from the same spot....
One from the rear...
And one from the front...
Last edit: 19 May 2021 16:15 by X8GGY.
19 May 2021 17:36 #235210
That's a pretty spot
19 May 2021 19:26 - 19 May 2021 19:27 #235211
Zoomed in on the 'lane...
We'll be driving that one again on Sunday in the group's first post lockdown laning day!
More on that later, first...
Thanks Lambert... it's here on the map. in the black rectangle not far from my house -That's a pretty spot
Last edit: 19 May 2021 19:27 by X8GGY.
Time to create page: 0.243 seconds
