- Thank you received: 542
18 Jan 2021 14:16 #231926
Replied by jackonlyjack on topic Dave's la(te)st buggy build...
I was reading a FB post they mentioned attaching suitable length strength spring
Around brake hoses to pull them back into a desired location
Also allowing full articulation
- Thank you received: 1346
18 Jan 2021 16:44 #231928
Dreadnaught (black 2011)
Land Rover have something like a plastic spring on the front lines on defender.
- Thank you received: 467
18 Jan 2021 16:45 - 18 Jan 2021 16:45 #231929
Pickup/tipper, R7me gearbox & 4.3 Rocklobster, 31" Toyo MT, 2x ARB 3.9 diffs in braced axles, 6" total lift, Floating rear conversion, Raptor painted, CB, Recaro's, Caged, etc, etc...
Replied by Riccy on topic Dave's la(te)st buggy build...
Looking good Dave
And I like JackonlyJack's spring suggestion for brake pipes, very clever solution to keeping them clear. Llama4x4 will make up jimny hoses at any custom length and for a good price too
Last edit: 18 Jan 2021 16:45 by Riccy.
- Thank you received: 735
18 Jan 2021 19:03 - 19 Jan 2021 06:58 #231935
Thanks All..
I've already got the brake hoses -
Stainless TrailGear ones from JimnyBits...
It's the actual brake pipes I need to re-route to the flexi hose connections, as the wings have gone!
I've got Alan's old faithful flaring and bending tools to assist with job, so that shouldn't be too bad a job...
What I'm NOT looking forward to is the headlight wiring!... Suzuki, in their wisdom?!
, use negative switching on the headlights of Jimnys (and Vitara, Gand Vitara, etc) to save one cable as far as I can see?!
So when the ignition is on, the three wires to the headlight are all live / positive, when you switch to sidelights one of the wires drops to earth / negative, and when you switch dipped lights on another different wire drops to earth / negative, and you guessed it, when you select main beam the third wire drops...?! So for me to use "normal" (JCB!) headlights is a mini-nightmare
I've been giving it some thought recently though... I did buy an aftermarket kit-car headlight switch, but I'd rather they worked on the stalk as Suzuki intended...
So the sidelights can be connected to the rear light wire in the loom by the passengers feet (I did this for the DRLs on the Gold Jimny that GusTheGorilla now has), so they'll come on as the stalk is twisted to the first position...
The dipped and main beam I figure I can do with two relays wired for earth-switching using the two headlight wires... as done for light bars, etc... A bit of a phaff but will allow all the lights to work off the stalk as intended... more on that when I tackle it soon'ish...
Last edit: 19 Jan 2021 06:58 by X8GGY.
19 Jan 2021 16:53 #231959
Better get my spanners spinning quicker!...
Just committed to some of Brett's trips this summer *Covid-willing
May - local to me, the Buggy's inaugural (group) trip!
20th June - BigJimny Meet
June - the Peak District
July - North Yorkshire weekend
August - local to me
September - Chirk / Oswestry area (fairly local to me)
and possibly...
November - the Lake District (for the day!)
and possibly...
20 Jan 2021 21:18 #232013
Another good day in the garage tpday...
Rear lights finished! The high-level brake light is wired up, and the guards are back on the SJ rear lights... So, that's the rear finished! The rear brakes have already been done, so I turned my attention to the front...
I made a bracket for the engine battery's isolation switch... just need to wire from the switch to the battery now...
And then I final-fixed the JCB headlights and began fathoming out the wiring, what joins to what... you can see the indicator is "on" in this photo, it wasn't a lucky shot with the camera
I ran a cable from the side lights and used that to work out what wire did what in the JCB headlights... So I think I'm all ready to wire up the headlights on Sunday
The horn still works! So that was attached to the bracket that holds the front of the relocated air-box...
Oooh, I forgot, I had a couple of interuptions today... the first was a flood alert message from Natural Resources Wales, so I wandered down to the river for a look... it was wide, deep and fast flowing, but well within the flood banks (at 3pm), so should all be okay....? And this morning I had a package from JimnyBits... My co-driver Alan has recently bought Darren William's Jimny! And his grandson is giving it the once over... so I sent him a set of king-pin and axle ball seal bolts, but he asked if he could borrow my front bearing lock nut tool... But, I couldn't find it?! It's in the garage somewhere, but has had some use and had a wobbly peg, so I just ordered a new one! It arrived this morning, so I messaged him and he popped in to collect it this afternoon...
21 Jan 2021 06:33 #232022
22 Jan 2021 11:45 #232064
That's seven years bad luck for me then...
Just drove the buggy out of the garage to turn it round (started first turn!) to do the front electrics on Sunday, banged a bit with the Lockright (Lunchbox cheaper make) in the rear... I realised on Wednesday that I'd inadvertently cut the mirror remote wires off the loom in the drivers door, so I went to manually move the mirror whilst reversing in and .., CRACK!
Good job I've got a spare...
22 Jan 2021 17:08 #232081
I was waiting for our Londis delivery truck this morning, so I was playing at making videos again...
A little video to try and show how the rear mounted winch works...
And work out the basics of video editing and sub-titling...!
22 Jan 2021 17:22 #232083
Shame about the mirror, but at least the winch works an absolute treat. Very clever and very well executed
- Thank you received: 313
22 Jan 2021 20:11 #232093
Replied by Soeley on topic Dave's la(te)st buggy build...
Nicely done!
25 Jan 2021 07:00 - 25 Jan 2021 07:11 #232163
No work on the buggy yesterday...
I needed a lie-in, and didn;t wake up until10:45! So a cooked breakfast and a nice long walk with the Labradors in the snow
And then I was working on the wife's car... she's got a Mokka 4x4 and went to use it Saturday to go shopping, and started the wipers to clear the windscreen not thinking they were frozen to the windscreen and covered in snow, so it ripped the blade off the driver;s side and both wier arms jumped on the splines and went out of alignment., so defrost the car, disassemble, off to Halfords for a new blade, and then realign everything so that the wipers didn't smash into each other and swipe straight off the windscreen too...
I then did some ZookBOB tidying up and some orders, and then jumped in a 40 degree hot-tub with a 4 degree Stella or two...
Back to the buggy on Wednesday...
Last edit: 25 Jan 2021 07:11 by X8GGY.
Time to create page: 0.340 seconds
