- Thank you received: 923
Reassembled the back a bit... spare wheel strap in, the faux Jerry Can that holds my tree strop bolted back in, the spare relocated and strapped down, which in turn clamps the ground anchor 'spade' in place. and the hi-lift jack mounted inside across the X in the cab...
And the seatbelts reattached too...
New soft-top front section arrived this morning, so it would be rude not too...
Sounds simple enough...
LOL "Remove these screws" that have been in place for twenty years!!!
Beat them into submission with a suitably sized screwdriver and a big hammer... "tapping them lightly' ( ) can shake them loose a bit!
And of course one of the four refused to come out and rounded off the crosshead hole in the top... so I angle grinded a slot across it and attacked with an even bigger screwdriver!
All out in the end though and the old hood removed...
On reassembly I replaced the old "screws" (M6 bolts actually) with some nice new stainless steel ones with hex heads...
A fair bit of fiddling about later...
And finally the new hood is in place...!
So I've left it down to stretch into place in my nice warm garage...
More soon!
- Thank you received: 1759
- Thank you received: 116
Mr. Sheen sort of thing then Maverick?
I started by marking a tape line along the sill and then undersealed the bottom of the sills inside and out with Hammerite Underseal -
With added Waxoyl
Messy job but well worth it...
I then attacked the JimnyBits side bars with a sanding sponge... one done!
And then the other... you may remember I got these reasonable as they somehow ended up with two of the same side at the end of a production run, so I cut and shut one to make it right for the other side... They've been on the buggy during the build so have been scuffed and dripped on with filler and paints, so I decided to sand them down and repaint them... I wonder what colour?!
While they were put to one side to dry I started reassembling the rear mudguards
All stainless fixings everywhere
Aha, there you go... if you hadn't guessed the colour of the sidebars, there they are in the background of this photo Yella to match all the other added bits of tube!
Done!
I'm hoping the windscreen guys will be here Monday or Tuesday...
Wednesday I'll bolt the sidebars back on and give them a second coat on the buggy, as it's very hard to paint both sides nicely on a pair of trestles! I hope the first coat doesn't look too bad... From doing the tubes of the "rollcage" it will probably take three coats to get them looking perfect!
The JCB Yellow paint is an agricultural enamel paint so should be much stronger than the standard black powdercoat and easy to patch up along with the rest of the buggy if (when!) they sustain any scrapes or knocks...
Wednesday I'm also hoping to get the snorkel back on and then refit the front mudguards too, after the windscreen guys have been...?
So more soon then?!
Both rear mudguards refitted...
So the back just needs the Samurai rear lights and guards added, and the foglight and high level brake light...
Getting there!
- Thank you received: 82
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Dirtbird wrote: Looking good
Thanks!
Lambert wrote: It's not going to be long before you are booking the mot.
Indeed...
... BUT, there's still a lot of wiring to do, etc, and I've still got the winter 'lockdown's to fill working in the garage until the sun eventually comes out next year and the COVID clouds disperse, so I'll be keeping myself busy with it for a while yet...
When I use stainless nuts and bolts I always grease them so that they do no stick together.
There goes my day in the garage then?...
IISY ?
