Ulysses
- Thank you received: 1759
- Visitor
- Thank you received: 923
jackonlyjack wrote: Built in sub back massager for them long trips
I like it.......I would have considered a 12v fridge in the centre
As you mentioned it, I thought best to check the one I have fits, and it does. Perfectly, which is a happy coincidence, rather than good planning
Lambert wrote: The passenger side enclosure needs a big phat amp in it with geometric wire paths and a soft red back light. That would be sick!
Amps are too big, so going under the seats.
There are two Alpine's Ive had in the shed from years ago. One is a 500w class D mono for the sub and the other is a 340w 4 channel for the small speakers (of which I have 2 sets of components to replace the pants standard ones). I do have another 500w mono and sub, but no space for it. Lights in the storage alcoves are a possibility though
S200KYS wrote: A man of many talents
The joinery isnt difficult if its going to be covered in carpet (hides a lot of sins), but thankyou for the kind words.
Now brace yourself for some crap upholstery...
and the next project is...
Stainless exhaust
This will use the 2" 4-2-1 manifold I already have and expand to 2.5" through a sports cat and single back box. Looks complicated when its in bits like that though! Had a quick play with the stainless mig wire and argon gas on a bit of it and its actually pretty easy to weld thankfully.
Daniel30 wrote: Great work that will make you sick when you turn it up! Love it
No puking allowed If anyone near me is sick, it instantly makes me ill
I used to have this all the alpine stuff in the back of a fiat bravo in my boy racer days and it would make the roof bulge when turned up, so theres gonna be enough power in a tiny cab like mine with just the one sub
- Thank you received: 651
Nice bit of luck with the fridge
- Visitor
Most definitely, I can't see out the rear view mirror in the jim or the mini with the music up to a good level
I think you're fuel usage probably is right for a Jimny running a 1.8 on those sized tyres through that gearing and with that weight! Albeit you've effectively chopped half of the body off!
You've got a load area I the back that could carry fuel and a funnel though.
Started at Barmouth and headed to Corwen the scenic way. As Barmouth is a long 4.5hr drive for me and Joel we went down the night before and stayed in a b&b.
