× Are you building a Mud Monster or a Pavement Princess??
Ulysses
19 Dec 2018 23:18 #199207 by sniper
Replied by sniper on topic Ulysses
I've been considering trimming my OE bumper down to somewhere near your fabricated one. Then making a front plate from 75x25 box that will carry tow points, not far off where you are.....
sniper
20 Dec 2018 05:52 #199210 by jackonlyjack
Replied by jackonlyjack on topic Ulysses
I would say 6 or 8 mm C section steel will work better
  • Riccy
  • Riccy's Avatar Topic Author
  • Online
  • Site Sponsor
  • Site Sponsor
  • J999 MNY Bashing around Carlisle
20 Dec 2018 18:24 #199236 by Riccy
Replied by Riccy on topic Ulysses
sniper wrote: I've been considering trimming my OE bumper down to somewhere near your fabricated one. Then making a front plate from 75x25 box that will carry tow points, not far off where you are.....
sniper
something like this on J999MNY was easy to make and it attaches to the jimnybits towpoints (its original plate is on show, thats how long this thing has been stuck there!).
That is mostly box section and a bit of thin plate. Not intended to bash holes in the countryside, just neaten up and cover the chassis rail ends. That was before i chopped a big hole in it for the winch :laugh:
Pickup/tipper, R7me gearbox & 4.3 Rocklobster, 31" Toyo MT, 2x ARB 3.9 diffs in braced axles, 6" total lift, Floating rear conversion, Raptor painted, CB, Recaro's, Caged, etc, etc...
20 Dec 2018 19:05 #199240 by sniper
Thats pretty close to what I was imagining, linked in to the chassis legs on mine, as I won't have the winch plate. A couple of weld on 3t lifting points and I was maybe thinking of a front tow ball.....
sniper
20 Dec 2018 21:11 #199251 by jackonlyjack
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
23 Dec 2018 17:37 #199351 by Riccy
Ive been having a wheelie busy time with these latley... Just the fronts to topcoat tomorrow once the backs dried. Toolstation 'Jet black' from the industrial spray paints bit.
Tyres off and cleaned up with many different sorts of wire brush on a grinder/drill...
Quite like the bare metal colour, but its on with the primer...
then todays progress with the top black...
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
23 Dec 2018 17:41 #199353 by Riccy
jackonlyjack wrote: I found these other week after i had sorted mine lol
cheap and ready to weld on
www.screwfix.com/p/hardware-solutions-ey...15-x-65-x-45mm/291cc
I would be a bit wary of using those as towpoints Jack... They are only as good as how they are welded on, and what they weld onto.
I chose to make longer plates to bolt in several places inside the chassis rails on the ones i made, that way they are not going to fly off and kill someone in the event they are used harshly (this is because i dont trust the quality of my welding enough for this job!)
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
23 Dec 2018 18:03 #199354 by Riccy
sniper wrote: Thats pretty close to what I was imagining, linked in to the chassis legs on mine, as I won't have the winch plate. A couple of weld on 3t lifting points and I was maybe thinking of a front tow ball.....
sniper
see above re weld on towpoints. Bolt on swivel ones are available, which would be a safer option, or just longer thick plate right through. In the above pics there is no winch or winch-plate, its just held on by the mounting bolts on the Jbits front tow points, which are a) cheap and available, b) easy to fit and c) proven to be strong and secure.
See here for a tame example of what can happen, that guy wasnt badly hurt, but who knows what will happen...
23 Dec 2018 18:16 #199355 by jackonlyjack
Not to worry Pal i am having them welded to 6mm plate then welded into the chassis rails
by a man with great skills :)
23 Dec 2018 19:53 #199363 by OlaGB
Replied by OlaGB on topic Ulysses
sniper
Never use straps or firm ropes for this style of recovery, only kinetic ropes.. I bet those guys in that video would recover faster, and alot safer, using a kinetic rope.. A must have in all offroad viechles :)
23 Dec 2018 20:50 #199364 by jackonlyjack
I personally would never snatch recover anyone
Also I use a bridal to share the strain ;)
23 Dec 2018 21:13 - 23 Dec 2018 21:14 #199367 by OlaGB
jackonlyjack wrote: I personally would never snatch recover anyone
Snatch recovery doesnt have to be brutal.. Even slow speed snatch helps alot, and is way easier on equipment than a firm strap/rope..
But ofcourse, huge consequense if something snaps. Point is that its less likely to snap, compared to regular straps/rope.
Last edit: 23 Dec 2018 21:14 by OlaGB.
Time to create page: 0.262 seconds
Powered by Kunena Forum
