× Are you building a Mud Monster or a Pavement Princess??
Ulysses
09 Feb 2019 17:14 #202861 by jackonlyjack
  • Lambert's Avatar
  • Away
09 Feb 2019 17:44 #202865 by Lambert
Replied by Lambert on topic Ulysses
That looks well. Good work!
Dreadnaught (black 2011)
  • Riccy
  • Riccy's Avatar Topic Author
  • Online
  • Site Sponsor
  • Site Sponsor
  • J999 MNY Bashing around Carlisle
17 Feb 2019 17:40 #203348 by Riccy
Replied by Riccy on topic Ulysses
And now for the back end...
Made up some bolt-on plates and a tube to link between the chassis rails and support the trailer body...
Then tried some 2 plane pipe bending. Unfortunatley the bender I have is unable to make bends close together by its design, so I did have to cut, sleeve internally and weld a section on the drop of the side bars, but its pretty good and certainly strong enough in the scaffolding pipe. The side bars weld to the roof hoop and to the rear bolt-on plates.
And the trailer body fits nice and snug on the brackets:
Decided a bit of bracing was needed so have started on some kickers from the roof down to the mounting plates.
Next will be finishing the other kicker and onto the rock-slider part of it. That will also need to be a bolt on fixing of some sort to enable the cage to be removable, but that shouldn't be too hard. Rocksliders are basically box section steel to run along the sills and have kickers back to the chassis for strength.
Pickup/tipper, R7me gearbox & 4.3 Rocklobster, 31" Toyo MT, 2x ARB 3.9 diffs in braced axles, 6" total lift, Floating rear conversion, Raptor painted, CB, Recaro's, Caged, etc, etc...
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
17 Feb 2019 17:50 #203349 by Riccy
Oh yes,
and [virtual] bonus points if you can work out what I want to use one of these for:
:whistle: :dry:
17 Feb 2019 18:20 #203352 by sniper
Replied by sniper on topic Ulysses
Electric ram to make it tip ?????
sniper
(looking good Riccy, won't be long)
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
17 Feb 2019 18:38 #203357 by Riccy
Pah, was too easy I guess. Points to you my friend ;-)
Yes it was interesting to have a search for '12v waterproof linear actuator'. They are essentially similar to a hydraulic ram, except they are all-in-one and generally are designed to run from 12v DC, therefore, much cheaper and easier to install. Wiring is simply reversed to get the same action back in. Runs at about 20mm/sec but will be faster with how it's to be mounted.
The one pictured is good for 4000NM force in both directions, more than ample for the tiny bed on this project :-)
For the hinge point I have been looking at pillow block bearings from various engineering suppliers, these offer way more service life and lifting capacity than I will need, but are about £20ea for a simple block that can bolt on to the trailer body and allow it to swivel enough to work.
17 Feb 2019 19:45 #203361 by sniper
Cool, It's like winning the lottery... only different.... really different....
I used to build tipping bodies and compactors with tipping mechs for the bins, a bit of an insiders guess I suppose....
sniper
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
23 Feb 2019 18:14 #203722 by Riccy
Started bending more pipe to make the cage come over the roof and down the sides. Not too bad (apologies for the poor pics). More messing about tomorrow :-)
  • Lambert's Avatar
  • Away
23 Feb 2019 21:04 #203734 by Lambert
Coming along nicely!
  • Riccy
  • Online
  • Site Sponsor
  • Site Sponsor
24 Feb 2019 17:55 #203767 by Riccy
Some pics in better light. Had to remake the passenger side bar over the door after ballsing up the gob cut onto the rear hoop :angry:
Finally got it on and happy enough with it.
Next was starting on the bottom rockslider bar part of it. Cut some 50x50x3 box to fit and trimmed the bits of cage sticking down. Some spot welding to allow me to shift it about for alignment. Made up some bent arms to connect that to the chassis with some large spreader plates for bolting onto the rockslider bars. Actually managed to get a half decent weld on one of them as well :laugh:
Then a little bracket to attach to the original roof bar mounting points (well the front ones at least :huh: ). Nice thick bit of rubber cut and put under it as well. Pretty sturdy now. The cage will easily be strong enough to use as a jacking point.
still want to put a brace bar above the windscreen to link both side bars together, but need to do the rockslider bar and mounts on the driver side. Also thinking about a bar to come along the top of the front wings and connect to the bumper (brush bars).
  • X8GGY
  • X8GGY's Avatar
  • Site Sponsor
  • Site Sponsor
  • Suzukis - a life long obsession!
24 Feb 2019 18:14 #203770 by X8GGY
Replied by X8GGY on topic Ulysses
Good progress Riccy! B)
Is that buggy finished yet?...
  • Lambert's Avatar
  • Away
24 Feb 2019 19:57 #203782 by Lambert
I might be coming to you if I ever get really serious about track days and need a cage!
Time to create page: 0.221 seconds
Powered by Kunena Forum
