Suspension and Wheel Set Up
- Jimny08
- Visitor
- jonesyba420
- Visitor
is a road only jimny or do you offroad it regularly?
- Jimny08
- Visitor
- jonesyba420
- Visitor
anything over a 215 75 15 tyre starts to dramaticly alter the gearing, people have ran upto 32" tyres without altering the gearing and not destroying clutches BUT you have to drive with ALOT of mechanical sympathy.
you can see the spec of mine in my signature, i do quite alot of green laning and ive not been stuck since fitting the mud tyres.
- Jimny08
- Visitor
And just out of interest what would the next stage on from your Reccomendation be ie suspension lift etc
Thankyou for your time I have a lot of questions!
- TomDK
- Visitor
Jimny08 wrote: Hi thanks, it's mainly road use with occasional off roading
I would seriously consider the Trailmaster lift kit.
www.jimnybits.co.uk/shop/jimny/suspensio...t-kit/prod_1007.html
The trailmaster kit is great because it is tailored to the Jimny, and not some random US truck, like Rough Country and Pro Comp shocks are.
And the tyresize mentioned, 215/75/15 is fine for most offroading
Taller is not always better. I fact, keeping COG as low as possible is preferable for offroading.
- Thank you received: 75
i have said on many occasion, if i hadn't bought mine lifted i would have just put 195's or 215's on it and left the suspension standard. any lift puts strain on the drivetrain
standard jimny - for now
- TomDK
- Visitor
robs5230 wrote: any lift puts strain on the drivetrain
Please explain.
- Jimny08
- Visitor
really ?? are you trying to test my knowledge to see if i may trip myself up ? if my post is incorrect it would be more beneficial to the original poster that you give the correct information / correct me.TomDK wrote:
Please explain.
in my opinion, bigger tyres will follow lift. bigger tyres = more stress on the gearing.
axles and gearbox / transmission will not be in the position they were designed to be in.
if caster correction is not applied, the axles will not be sat correctly. axle to radius arms mounts take a beating.
i'm talking about suspension not body lifts by the way
- TomDK
- Visitor
Please explain.
I very much agree with you. Only your comment about any lift puts strain on the drivetrain that puzzled me.
Though I must say, fitting 215's on a 2" lift only adds very little strain, if any.
But 31" tyres fitted does put some strain on the CVs and shafts
Please explain.
