My tray back
- GuardianAngel
- Visitor
Vytrix wrote: It all depends how much u can do urself mate.
Nothing to be honest. Just interested how much if I were to hand over the J and said do the lot.
- badboy-jimny
- Visitor
- darthloachie
- Visitor
- Vytrix
- Visitor
- nicho
- Visitor
- Dave cc
- Visitor
Vytrix wrote: I like the sound of the bonding idea rather than welding, but I would bond it all together after you cut the back off as the centre of the cab is about 20-30mm wider than the rear end so you have to cut the frame in half and then weld the door on in the middle which leaves 10-15mm gaps either side which you need plate.
You are the man that is like the best bit of info you could have given me could save a whole lot of heart ache Owe you 1 for that
- JivingDaddy
- Visitor
- Vytrix
- Visitor
- Vytrix
- Visitor
Wat u mean on the rims? I welded it to the rock sliders. The problem with the cage is that the only way to see if it works is to roll it!!!!JivingDaddy wrote: That is one hell of a cage, but how do you attach it? Also, couldn't you have used green tape to match the car instead of purple?!
- Vytrix
- Visitor
- Vytrix
- Visitor
- Jimny - aus
- Visitor
