adamjimny
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 18:05 #65188 by adamjimny
Replied by adamjimny on topic adamjimny
the fuel pump on my tank is leaking and its coming up with check engine light which could be something simple or not.
itll get there
  • reaper
  • Visitor
  • Visitor
10 Mar 2013 18:12 #65191 by reaper
Replied by reaper on topic adamjimny
Wow thats a busy weekend !
If i was closer id have the old shell off you ive been dying to make a hindged fastback for a soft-top
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 18:14 #65192 by adamjimny
its taken all week pal. alot of work to say i have a very small garage and a public carpark to do it on
  • reaper
  • Visitor
  • Visitor
10 Mar 2013 18:24 #65194 by reaper
Does look at tight fit in the garage :-)
Are you fitting the ''old'' arches on the new shell then mate ?
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 18:33 #65195 by adamjimny
reaper wrote: Does look at tight fit in the garage :-)
its really tight ....especially when it has a load of stuff at the back too
no definetly not fitting the LR arches back on. never liked them and never will....only fitted them because i had to cover the tires. not sure what route ill take with arches next
maybe kap arches or something else......want it to look neat
10 Mar 2013 18:37 #65197 by j999pre
Replied by j999pre on topic adamjimny
adamjimny wrote: the fuel pump on my tank is leaking and its coming up with check engine light which could be something simple or not.
itll get there
Are you using your old ecu or the hard top one? Could be that as the part numbers are different and the hard top ecu might not like the signal from the crank sensor?
Where is the tank leaking from. I think I have a spare one you could butcher for bits.
Grey pick up Jimny
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 18:47 #65202 by adamjimny
j999pre wrote: Are you using your old ecu or the hard top one? Could be that as the part numbers are different and the hard top ecu might not like the signal from the crank sensor?
old ecu and wiring loom new locks.....may be the code ring not 'agreeing' with old ecu
on the fuel pump section....not sure exactly will be dropping tank this week to check....may be a fuel pipe union got caught with new body while mounting
  • reaper
  • Visitor
  • Visitor
10 Mar 2013 18:54 #65203 by reaper
How about some of these :-)
www.lowrangeoffroad.com/index.php/flexy-...ide-by-the-foot.html
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 19:01 #65207 by adamjimny
thats just what im looking for cheers
  • nicho
  • Visitor
  • Visitor
10 Mar 2013 21:25 #65233 by nicho
Replied by nicho on topic adamjimny
looks $1000 better.n it looked good before.
  • adamjimny
  • Visitor
  • Visitor
10 Mar 2013 21:39 #65235 by adamjimny
Thanks
Still got to do:
ORA rear bumber to mount
arches to trim
Rust to cut out
And main one get him running! Ha
  • supergaz
  • Visitor
  • Visitor
10 Mar 2013 21:49 #65239 by supergaz
Replied by supergaz on topic adamjimny
I'm impressed on how much you have achieved on the jimny just with your little garage and in the carpark. I've been off work all week and all i've done is bung a new starter motor in and ripped out my rocklobster so it can have a service by Rockwatt. And I have the luxury of having my jimny in a big garage.
