05 A/T 2" trailmaster, 235/75
- zaine
- Visitor
18 Jul 2012 13:12 #44476
by zaine
Replied by zaine on topic Re: 05 A/T 2" trailmaster, 235/75
i thought that would be the case
good on him for having a go and doing something different though
- ShuDuck
- Visitor
18 Jul 2012 14:28 #44477
by ShuDuck
Replied by ShuDuck on topic Re: 05 A/T 2" trailmaster, 235/75
How so? I belive the stock ECU will be able to adjust to the small increase in cc. This have been done numerous of times in australia etc. with good results. However it is far easier with a piggy back to tune it should it be neccesary. You are the only one saying otherwise in all my searching, but I am taking it into consideration as I will research it further
- panosd
- Visitor
19 Jul 2012 07:17 - 19 Jul 2012 07:18 #44517
by panosd
Replied by panosd on topic Re: 05 A/T 2" trailmaster, 235/75
We have made conversions from m13a to m15a , m13a to m18a , m13a to vitara V6.
All of them required their own electrical systems in order to work properly.
Its easy to figure it. A m13a needs less fuel than a m15a. Akso the 1300cc has different main unit map.
If you want to have a 1500cc engine working as a 1300cc engine go for it.
But if you want to make something good then there is only one way, the right one by using all the
systems from the new one.
Last edit: 19 Jul 2012 07:18 by panosd.
- ShuDuck
- Visitor
16 Mar 2013 10:27 - 16 Mar 2013 10:28 #65866
by ShuDuck
Last edit: 16 Mar 2013 10:28 by ShuDuck.
- Beano
- Visitor
16 Mar 2013 11:13 #65870
by Beano
Replied by Beano on topic Re: 05 A/T 2" trailmaster, 235/75
How does it run?
- darthloachie
- Visitor
16 Mar 2013 11:21 #65872
by darthloachie
Replied by darthloachie on topic Re: 05 A/T 2" trailmaster, 235/75
neat job looks like it was there from new
- gaz3359
- Visitor
16 Mar 2013 11:22 #65873
by gaz3359
Replied by gaz3359 on topic 05 A/T 2" trailmaster, 235/75
Tidy truck conversion looks factory
- ShuDuck
- Visitor
16 Mar 2013 19:27 #65967
by ShuDuck
Replied by ShuDuck on topic 05 A/T 2" trailmaster, 235/75
Its got much more torque, and suits the automatic quite nice. Before I had to shift manually to 3rd gear on hills etc. But now I can add a little trottle, it drops out of lockup and I still have the power to take the hills. With the M13A I had to press the pedal t the floor to make anything happen if I did not gear manually. So instead of applying trottle, I shifted up and down :laugh: much more torque off idle as well
I used the M13A intake, exhaust (welded a crack between cyl 1 and 2), sump, pickup etc. So it looks exactly like stock
I have some pics from the swap, Ill post them with comments a bit later
- ShuDuck
- Visitor
05 May 2013 16:56 #70060
by ShuDuck
- ilten
- Visitor
05 May 2013 17:16 #70062
by ilten
Replied by ilten on topic 05 A/T 2" trailmaster, 235/75
Looking pretty good. I think at some point I have to find a bigger engine too. Still hoping I will find a cheap Vitara 1.6l one day.....
ilten
ilten
- ShuDuck
- Visitor
05 May 2013 19:10 #70084
by ShuDuck
You have the g13bb in yours?
05 May 2013 19:20 #70088
by Halford
Replied by Halford on topic 05 A/T 2" trailmaster, 235/75
those alloys look pretty good painted white
mine are well blistered and bubbled and on the list to be done (but it's a long list) :whistle:
think I'll go for a dark colour or possibly khaki
Time to create page: 0.192 seconds
