VAXXi's Jimny (Little Tank)
- VAXXi
- Visitor
02 May 2011 11:12 #15762
by VAXXi
Replied by VAXXi on topic Re: VAXXi's Jimny (Little Tank)
Phew, that was a long introduction. What's next:
- castor correction bushes
- LED strips for interior lighting
- front bumper (when I'll break this one) + spotlights]
- sound proofing the doors and front floor
- alexb25
- Visitor
02 May 2011 12:29 #15768
by alexb25
Replied by alexb25 on topic Re: VAXXi's Jimny (Little Tank)
Welcome to bigjimny, vaxxi!
- little jimny
- Visitor
02 May 2011 15:15 #15774
by little jimny
Replied by little jimny on topic Re: VAXXi's Jimny (Little Tank)
That's a great set of photos you've posted up. I'm tempted to do some sound deadening too, so I'm looking forward to the next set of photos of you doing the front doors and front floor.
- myers647
- Visitor
02 May 2011 18:08 #15787
by myers647
Replied by myers647 on topic Re: VAXXi's Jimny (Little Tank)
hi mate nice jimny does it go ok on the road with out the caster corrected bushes? and also where did you get the under body armour from.?
thanks
james
thanks
james
- VAXXi
- Visitor
03 May 2011 08:00 - 03 May 2011 08:02 #15805
by VAXXi
Thank you. I cannot recommend it enough, it's been one of the most rewarding projects for the Jim. As mentioned, I only did the rear panels + rear plastic trim + the floor; music sounds much better now, there are no more rattles and it's much more quiet in the cabin (to get an idea, the noise level at ~100 km/h now matches the noise level at ~70 km/h before the insulation). I must also say that I did a lot of planning when choosing the material, as it's not a one-size-fits-all kind of job. But it was worth it
I expect the floor and doors sound proofing to reduce further more the noise level, and I also want to do the roof at some point for thermal insulation.
Keeping in mind that I've driven only two Jimnys (a very stock one and my own), that's all I can compare with. The stock one had a more precise direction and the steering wheel was properly returning to center after a curve. My own Jim has a bit more vague steering and the wheel doesn't quite return to center, but I suppose that could be also because of the steering stabiliser. To sum it short: it's not that bad and you can definitely live with it, but it could surprise an unexperienced driver.
The underbody is around 100 euros, made in Czech Republic and imported by a Romanian company; here . I installed it in order to protect the transfer case wiring, which I understand it's very easy to rip off.
little jimny wrote: That's a great set of photos you've posted up. I'm tempted to do some sound deadening too, so I'm looking forward to the next set of photos of you doing the front doors and front floor.
myers647 wrote: hi mate nice jimny does it go ok on the road with out the caster corrected bushes? and also where did you get the under body armour from.?
Last edit: 03 May 2011 08:02 by VAXXi.
- MRocha
- Visitor
04 May 2011 18:21 #15878
by MRocha
Replied by MRocha on topic Re: VAXXi's Jimny (Little Tank)
welcome
Time to create page: 0.197 seconds
