VAXXi's Jimny (Little Tank)
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 10:52 #15755 by VAXXi
VAXXi's Jimny (Little Tank) was created by VAXXi
Hello everyone. Been reading for a long while, but the mention of the wobble PDF made me register :) The Jimny was bought in september 2010; it's a 2007 edition, 1.3 petrol, seems to be JLX spec.
What's on it so far:
- ProComp springs and shock absorbers, 1" body lift
- TJM snorkel
- OME steering stabiliser (previous owner said it was for the death wobble; now it only shuddered slightly at 70-80 km/h, but this was fixed after proper balancing of the wheels)
- flanges
- front bumper trimmed and a small bash plate fitted
- BF Goodrich 215/75R15 A/T
- CB antenna (FM) mounted on roofrails and CB radio of course
Previous owner also had a roof carrier fitted, which I've taken down because it was not used (and could not enter most underground parkings anymore :laugh: ).
Flanges:
[IMG
[IMG
[IMG
Steering stabiliser:
[IMG
New suspension:
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
Snorkel:
[IMG
[IMG
[IMG
[IMG
Front bumper trim:
[IMG
[IMG
BFGs fitted:
[IMG
[IMG
[IMG
[IMG
Front bash plate painted black:
[IMG
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 10:55 #15756 by VAXXi
Replied by VAXXi on topic Re: VAXXi's Jimny (Little Tank)
Next came the CB antenna and radio. This was a very complicated topic, because I wanted as good performance as possible on a permanent setup, while avoiding damages to the body (and I'm also a perfectionist :P ).
In the end, I decided to put it on the roof rail in order to use the roof as a ground plane. A grounding cable was needed in order to achieve a good SWR, and I still have to finish up the work properly (current grounding is done through a small braided wire, which isn't perfect), but it works good enough. My previous antenna was a 2 meter Sirio; adding the 2 meters of the car, it made driving through the city or under trees quite a challenging task, so I changed to a lighter 170 cm Sirio which is pretty ok so far.
[IMG
[IMG
[IMG
[IMG
The radio is an Intek M550, mounted on the cup holder. Initial plan was to mount it under the center column and lighter, but there was not enough room because of the airbag controller, so I relocated it. Under the cup holder I also found the airbag sensor, so had to be extra-careful working under there :dry: The radio is powered directly from the battery with a 15 amp cable, fused and routed through the firewall rubber grommet and under the carpeting.
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 10:56 - 02 May 2011 11:03 #15757 by VAXXi
Some phone pics after a wash (including the engine bay):
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
Some other pics:
[IMG
[IMG
[IMG
[IMG
In the snow:
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
Lake side:
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
More pics:
[IMG
[IMG
[IMG
[IMG
Last edit: 02 May 2011 11:03 by VAXXi.
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 11:05 #15758 by VAXXi
The Jimny had HID lights when bought, 8000o K and a crappy wiring. Too white for my taste, so I bought a new wiring loom (with hi/lo switcher), new ballasts and new 6000o bulbs.
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
[IMG
New cabin filter installed:
[IMG
[IMG
Rust :angry:
[IMG
[IMG
[IMG
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 11:06 - 02 May 2011 11:13 #15759 by VAXXi
Underbody protection:
[IMG
And a better "voice" for the tank :evil: The stock horn is a 4 A Denso, which is also mounted on motorcycles. Since the wires were too thin for the Stebel (which draws up to 16 A), a relay circuit had to go in place.
Connection to the battery through a 1.5 square mm wire (I really need to get a fused distributor box :laugh: )
[IMG
Relay in place of the old horn
[IMG
New horn (136 dB !)
[IMG
Testing the circuit and connections
[IMG
[IMG
Wire route
[IMG
Last edit: 02 May 2011 11:13 by VAXXi.
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 11:07 #15760 by VAXXi
And finally, one of the best investments for confort: sound proofing.
The goods (from Russia with love from StandartPlast):
[IMG
Factory vibration dampeners in the plastic panels (LOL):
[IMG
[IMG
Plastic panels properly dampened:
[IMG
[IMG
[IMG
Degreaser for the metal (isopropylic alcohol):
[IMG
Bituminous material for the arches and side panels:
[IMG
[IMG
Some of the same in the rear speakers's area and the seatbelt mechanism bolts to get rid of the buzzing:
[IMG
[IMG
[IMG
Thick sound dampener for the floor:
[IMG
As I don't use the rear seats, out they go and carpeting takes their place (still have to arrange the top margin properly):
[IMG
[IMG
Mucho better :woohoo:
  • VAXXi
  • Visitor
  • Visitor
02 May 2011 11:12 #15762 by VAXXi
Phew, that was a long introduction. What's next:
  • castor correction bushes
  • LED strips for interior lighting
  • front bumper (when I'll break this one) + spotlights]
  • sound proofing the doors and front floor
  • alexb25
  • Visitor
  • Visitor
02 May 2011 12:29 #15768 by alexb25
Replied by alexb25 on topic Re: VAXXi's Jimny (Little Tank)
Welcome to bigjimny, vaxxi!
  • little jimny
  • Visitor
  • Visitor
02 May 2011 15:15 #15774 by little jimny
Replied by little jimny on topic Re: VAXXi's Jimny (Little Tank)
That's a great set of photos you've posted up. I'm tempted to do some sound deadening too, so I'm looking forward to the next set of photos of you doing the front doors and front floor.
  • myers647
  • Visitor
  • Visitor
02 May 2011 18:08 #15787 by myers647
Replied by myers647 on topic Re: VAXXi's Jimny (Little Tank)
hi mate nice jimny does it go ok on the road with out the caster corrected bushes? and also where did you get the under body armour from.?
thanks
james
  • VAXXi
  • Visitor
  • Visitor
03 May 2011 08:00 - 03 May 2011 08:02 #15805 by VAXXi
little jimny wrote: That's a great set of photos you've posted up. I'm tempted to do some sound deadening too, so I'm looking forward to the next set of photos of you doing the front doors and front floor.
Thank you. I cannot recommend it enough, it's been one of the most rewarding projects for the Jim. As mentioned, I only did the rear panels + rear plastic trim + the floor; music sounds much better now, there are no more rattles and it's much more quiet in the cabin (to get an idea, the noise level at ~100 km/h now matches the noise level at ~70 km/h before the insulation). I must also say that I did a lot of planning when choosing the material, as it's not a one-size-fits-all kind of job. But it was worth it B)
I expect the floor and doors sound proofing to reduce further more the noise level, and I also want to do the roof at some point for thermal insulation.
myers647 wrote: hi mate nice jimny does it go ok on the road with out the caster corrected bushes? and also where did you get the under body armour from.?
Keeping in mind that I've driven only two Jimnys (a very stock one and my own), that's all I can compare with. The stock one had a more precise direction and the steering wheel was properly returning to center after a curve. My own Jim has a bit more vague steering and the wheel doesn't quite return to center, but I suppose that could be also because of the steering stabiliser. To sum it short: it's not that bad and you can definitely live with it, but it could surprise an unexperienced driver.
The underbody is around 100 euros, made in Czech Republic and imported by a Romanian company; here . I installed it in order to protect the transfer case wiring, which I understand it's very easy to rip off.
Last edit: 03 May 2011 08:02 by VAXXi.
  • MRocha
  • Visitor
  • Visitor
04 May 2011 18:21 #15878 by MRocha
Replied by MRocha on topic Re: VAXXi's Jimny (Little Tank)
welcome
Time to create page: 0.211 seconds
