Late Gen3 with DAB radio
13 Feb 2023 09:07 #247583 by mlines
I get the feeling that the standard DAB radio installation (Dealer fit or Factory fit) has an aerial on the screen?
Does anyone have a good alternative installation? If external, how do you get the wire though the body.
Sent from my moto g42 using Tapatalk
13 Feb 2023 10:16 #247585 by DrRobin
Replied by DrRobin on topic Late Gen3 with DAB radio
I have a Mag-Mount on the roof at the rear. My Gen 3 has a DAB USB dongle and it started getting interference from the 360 Degree camera system, so I placed the DAB dongle under the rear seats and 'earthed it' using copper tape, I threaded the USB cable under the carpet and round the centre console. Then I took the [thin] coax through the boot, behind the side panels and up the rear door trim, tucked it in to the rear door rubber and then out a short distance to the antenna.
The cable is largely hidden both inside and out.
I will find my pictures and post a few.
Robin
13 Feb 2023 10:16 #247586 by Lambert
Replied by Lambert on topic Late Gen3 with DAB radio
Paying attention to this as mine was removed and reused when I had a replacement screen and it's not the best.
13 Feb 2023 10:40 #247587 by DrRobin
My windscreen mounted antenna worked very well, until it picked up too much noise from the head unit and camera system. Through many hours of research a mag mint on the rear and the DAB mounted under the rear seat was the solution.
The DAB dongle
You could use your spectrum analyser to check for noise, look around 220MHz or even connect it to the antenna and check for best signal.
Route the cable under the edge of the carpet/trim to the rear door hinge, through the door seal (I used the side to stop sitting water) and then out onto the roof.
Robin
13 Feb 2023 10:51 #247588 by Lambert
That's way more than I need, as it stands my current hu isn't dab so for me I'm more after something that looks the part is I ever reverted to standard.
13 Feb 2023 11:09 #247589 by mlines
Replied by mlines on topic Late Gen3 with DAB radio
Anyone tried one of these?
amzn.eu/d/f7yRHN2
