Suspension upgrade suggestions for towing a Cargo Trailer please!
- TillymintDLG
27 Jun 2020 08:47 #224050
by TillymintDLG
Suspension upgrade suggestions for towing a Cargo Trailer please! was created by TillymintDLG
Hi Guys...
I am considering getting a Box Van trailer. It's a Braked single axle with a Gross weight of 1300 kg, Unladen it's 370 kg...
My '05 appears to have bog standard setup with 75k miles on it..As I can't find an aftermarket Standard length kit, I may as well do a 2" lift !
Can anyone recommend a kit for me? Am also thinking of a HD Rear propshaft too!
Thanks in advance..
Gaz
Thanks in advance..
Gaz
27 Jun 2020 09:22 #224054
by Busta
Replied by Busta on topic Suspension upgrade suggestions for towing a Cargo Trailer please!
Hi Gaz,
You shouldn't need to upgrade the suspension for towing. It's important that you observe the correct nose weight, and when doing so the car suspension should not be affected. That said, your 15 year old suspension will be quite tired by now so fitting new standard springs and shocks will see a big improvement.
You won't need an HD propshaft. I've towed with Jimnys for years and the only problem I've had related to towing was a stretched transfer box chain. That was on a car with a 1.6 conversion and 120,000 miles on the clock. In standard form the drivetrain (and the rest of the car) is very durable.
The following user(s) said Thank You: TillymintDLG
- TillymintDLG
27 Jun 2020 09:37 #224059
by TillymintDLG
Replied by TillymintDLG on topic Suspension upgrade suggestions for towing a Cargo Trailer please!
Thanks Busta, words of wisdom! I have to look sensibly don't I?
It is my daily driver but would like the ability to go 'mild' off road for wild camping... I will look into it!
I'm taking it to my local Suzuki dealer soon for a pre MOT (up in November) inspection re the drivetrain/suspension as desperate to get away this year!
Much obliged!
Gaz
Much obliged!
Gaz
27 Jun 2020 09:41 #224060
by Busta
A standard Jimny is perfectly adequate for mild, of even slightly wild off-roading. Obviously modifying a car is a personal thing and doesn't have to be rationalised, but it's certainly not necessary for the majority of situations!
- Thank you received: 1876
27 Jun 2020 09:43 #224062
Replied by Lambert on topic Suspension upgrade suggestions for towing a Cargo Trailer please!
Totally agree. A lift is going to create problems with getting the trailer to sit level and is totally unnecessary. There are plenty of manufacturers making standard road springs for a Jimny from suplex at the budget end to Klein and Suzuki at the top end. There are also loads of dampers available from all prices. If and it's a big if you're going to be doing as much or more than half your driving with said trailer on the back I can highly recommend the very expensive trailmaster sport dampers in standard length they eliminate pitch and roll and make towing a pleasant experience. However if you are not going to be towing regularly and are never very fully loaded they are very firm and you will find the ride is almost harsh, in this case the comfort version would be a better option.
- TillymintDLG
27 Jun 2020 09:45 #224063
by TillymintDLG
More money to spend on decent AT tyres Busta, I have mixed, cheap road tyres on it at the mo!
Gaz
Gaz
Time to create page: 0.487 seconds
