Re:Jimny's off road capabilities
- TautvydasP
- Visitor
02 Oct 2019 17:20 #214189
by TautvydasP
Jimny's off road capabilities was created by TautvydasP
Hello!
Currently, I am looking to buy a 4WD car that I could daily and off road. I am almost certain that i want a Jimny. As I started reading Jimny wiki I found one thing very concerning - Jimny has and older 4WD system that cannot be engaged on dry surfaces, so if I'm off roading on rocks or gravel (or any dry surface for that matter) I am basically stuck with RWD? Does this reduce Jimny's capabilities?
Thank you!
Thank you!
- Bill Portland
- Thank you received: 77
02 Oct 2019 17:52 #214191
by Bill Portland
Replied by Bill Portland on topic Re:Jimny's off road capabilities
Interested in reading responses to this
The following user(s) said Thank You: TautvydasP
02 Oct 2019 18:52 - 02 Oct 2019 18:53 #214196
by Gadget
Replied by Gadget on topic Re:Jimny's off road capabilities
The post title asks about off-road capability, but the post itself implies you're more interested in on-road use of 4wd?
The part time 4wd system in the Jimny, without a centre differential can't be used on a grippy surface, like tarmac, as there's no way for the front and rear to rotate at different speeds, which causes windup and expensive crunchy noises.
Off-road on a loose surface, including rocks and gravel, this isn't an issue as the terrain allows slippage between front and rear. The Jimny's off-road capability is excellent, being the equivalent of any other 4x4 with a locked centre diff.
If you want a full time AWD which automatically shuffles torque around when road conditions change suddenly, then the Jimny isn't the car you're looking for, however how often is that the case? What situation are you likely to be in where you suddenly have the need for all wheels to be driven? It's far more likely that you'll drive on tarmac and then transition to an unpaved surface, at which point you engage 4wd.
Last edit: 02 Oct 2019 18:53 by Gadget.
- Bill Portland
02 Oct 2019 19:00 #214201
by Bill Portland
And when on patchy ice? Just drop into 4H when you can't pull away but then back into 2H as soon as you start moving?
- Thank you received: 1839
02 Oct 2019 19:05 #214203
Replied by Lambert on topic Re:Jimny's off road capabilities
No it's just dry tarmac or similar that is a problem. Any surface that will allow a wheel to slip is ok for 4wd. In practice this means that on a paved road so concrete and tarmac you will be in 4x2 unless it's raining to the point where the entire road is covered in water. On every other surface like gravel or sand or grass or mud etc 4x4 should be engaged to provide the additional stability and traction. Yes a Jimny will get a lot further in 4x2 than a Ford fiesta but it will be safer in 4x4.
The following user(s) said Thank You: Gadget, TautvydasP
02 Oct 2019 19:05 - 02 Oct 2019 19:06 #214204
by Gadget
Pretty much. That's one of the limitations you get with the Jimny, an old-style transfer box doesn't allow you to benefit from 4wd in changeable on-road conditions, unlike having a centre diff. I'd hoped they would move to having a centre diff with the Gen4, like they did when going from the Series Landy to Defender, but sadly not.
Last edit: 02 Oct 2019 19:06 by Gadget.
Time to create page: 0.217 seconds
