1999 3sp Auto Box wiring questions?
03 Apr 2012 10:37 #36819 by Obarno
I only know from my own experience about the overdrive in that effectively it is a 4 speed box. I'm not aware that 4th is any weaker than the rest of the box, certainly I've had no problem and have used it off road with a rock lobster transfer box in all gears.
What you are proposing sounds excellent and it will be interesting to see the finished result.
  • X-Eng Simon
  • Visitor
  • Visitor
03 Apr 2012 12:03 #36820 by X-Eng Simon
Replied by X-Eng Simon on topic Re: 1999 3sp Auto Box wiring questions?
I presume that the normal selector just chooses between 1,2 & 3 and that there is a separate switch for Overdrive?
Will it let you select OD in a lower gear - i.e. is it genuinely an overdrive or just a higher gear?
If so, can you use it as a sort of inbetween gear - to give you a gear inbetween 1st and 2nd for example?
Si
03 Apr 2012 12:52 #36822 by Obarno
The selector has L ie 1st, 2nd and D which is really 3rd and above. There is a separate switch on the gear lever for o/d on and off. Really though, as you say it's a 4th gear as its not selectable for say 1st or 2nd to give a split gear.
Like most unaltered autos it will only change down when the speed Is right, rather than when you might want it to. I think though the o/d will come out at any speed, but I'm not totally sure as its not something I do very often, although I do switch the o/d off for hills to stop it shunting between gears.
  • Jande
  • Visitor
  • Visitor
04 Apr 2012 04:15 #36873 by Jande
Replied by Jande on topic Re: 1999 3sp Auto Box wiring questions?
i have jimny manual
just mail me, i send it email.
Time to create page: 0.138 seconds
