Removed cv joint, oil on my drive
  • ianR
  • Visitor
  • Visitor
01 Apr 2012 17:06 #36717 by ianR
Removed cv joint, oil on my drive was created by ianR
My CV joint went on a pay and play day last week, which a friend of mine removed on site so we could get home, it has sat on my drive since and now I have a load of oil leaked out of that side, Now this may be a silly question but i don't know, hence why i'm asking but where has the oil come from ?
01 Apr 2012 17:21 #36718 by facade
out of the front differential.
Likely he just pulled the half shaft out, the oil has run into the swivel housing and come out of the dust seal.
The following user(s) said Thank You: ianR
  • ianR
  • Visitor
  • Visitor
01 Apr 2012 17:22 #36719 by ianR
Replied by ianR on topic Re: Removed cv joint, oil on my drive
Thanks for answering that one, what oil will i need to top it up ?
  • vitara_mad
  • Visitor
  • Visitor
01 Apr 2012 17:55 #36721 by vitara_mad
Replied by vitara_mad on topic Re: Removed cv joint, oil on my drive
gear oil ep90
once the shaft is out there is nothing to seal the oil from leaking past the oil seal
  • ianR
  • Visitor
  • Visitor
03 Apr 2012 07:34 #36809 by ianR
Will it be ok to drive a few miles up the road to where I'm having the new cv fitted without topping it up as I will be in 2wd ??
  • vitara_mad
  • Visitor
  • Visitor
03 Apr 2012 08:55 #36812 by vitara_mad
it will be fine to drive it in 2wd with unlocked hubs as the front diff don't turn
Time to create page: 0.148 seconds
