Rocklobster prop question
17 Mar 2012 17:10 #35729
by kirkynut
Rocklobster prop question was created by kirkynut
I am lucky enough to have a late sammi front prop on the rear of My JimJam with the right flanges (my Mrs still laughes when I talk about flanges on a car!) but I can't remember why we use them - are they longer or shorter than a standard Jimny rear Prop?
Yes I could take mine off and measure it against my old rear prop but that's a faff so I thought I'd pick the brains of those in the know on here!!!
Cheers
Cheers
17 Mar 2012 17:34 #35733
by Obarno
Replied by Obarno on topic Re: Rocklobster prop question
The original Jimny prop is about 1 1/2 inches shorter than a Sammi front prop. I had an adaptor/spacer made for my rocklobster that bolts on to the Sammi flange and takes the original rear prop.
17 Mar 2012 19:38 #35746
by kirkynut
Replied by kirkynut on topic Re: Rocklobster prop question
Cheers for that.
Next question, why do we all use a longer prop and faff about with getting the right flanges and not just use a prop spacer that has the holes in it for all the different Zuk prop flanges?
- darthloachie
- Visitor
17 Mar 2012 20:48 #35758
by darthloachie
Replied by darthloachie on topic Re: Rocklobster prop question
problem with spacers is you end up with steeper UJ angles
- adamjimny
- Visitor
17 Mar 2012 20:54 #35761
by adamjimny
Replied by adamjimny on topic Re: Rocklobster prop question
And the jimny rear only extends a little bit but sj extends quite a few inches more
Sent from my GT-I9100 using Tapatalk
18 Mar 2012 06:22 #35774
by kirkynut
Cheers, I thought the UJ angle might come into it but hadn't thought about the spined part of the prop being longer on the Sj prop to allow more movement of it.
I knew there were good reasons and I'm sure I knew once but the theorist in me wanted the info stored in the old brain cells as I like to know the why's and wherefors with things - not understanding sends me mad!
Time to create page: 0.157 seconds
