Swivel leak but no play?
  • wanderinstar
  • Visitor
  • Visitor
12 Mar 2012 17:51 #35371 by wanderinstar
Replied by wanderinstar on topic Re: Swivel leak but no play?
Yes. I did it about 2 months ago.
  • Ads1987
  • Visitor
  • Visitor
12 Mar 2012 19:34 #35380 by Ads1987
Replied by Ads1987 on topic Re: Swivel leak but no play?
I assume you just unbolt the swivel seal and kingpin bearings and pull it off then?
  • wanderinstar
  • Visitor
  • Visitor
12 Mar 2012 20:00 #35384 by wanderinstar
There is a "How to " guide here. Tells you everything you want to know.
www.bigjimny.com/images/documents/Changi...KingPin_Bearings.pdf
  • Ads1987
  • Visitor
  • Visitor
12 Mar 2012 20:17 #35391 by Ads1987
yeah i've read the guides, very useful but just wasn't sure how the hub would come off without the tool to remove the drive shaft/bearing etc
  • wanderinstar
  • Visitor
  • Visitor
12 Mar 2012 20:40 #35396 by wanderinstar
Once you have removed the circlip and the square washer This will then allow you to take off the hub (once the kingpins have been removed). When you take the hub off the wheel bearing will come with it. Making it unnecessary to use the spacial tool to remove the wheel bearing.
Hope that I have made things clearer.
  • Ads1987
  • Visitor
  • Visitor
12 Mar 2012 21:24 #35401 by Ads1987
bit hard to imagine as i havent seen it really! i'll probably just buy the tool anyway, it's probably going to be useful in the future by the sounds of it! cheers for the info
Time to create page: 0.210 seconds
