Swivel leak but no play?
  • wanderinstar
  • Visitor
  • Visitor
12 Mar 2012 23:23 #35404 by wanderinstar
Replied by wanderinstar on topic Re: Swivel leak but no play?
Whereabouts are you located. It doesn't say on your profile.
  • Ads1987
  • Visitor
  • Visitor
13 Mar 2012 09:15 #35421 by Ads1987
Replied by Ads1987 on topic Re: Swivel leak but no play?
I'm in goudhurst in Kent, i've got an exploded diagram of the hub now and can see what you mean :)
I'm going to buy the hub tool anyway so I can have a decent look at the condition of the various bearings and seals etc properly. So i'll just replace the king pin bearings and shaft seal, but have a look at the wheel bearings and other seals.
Cheers!
  • Ads1987
  • Visitor
  • Visitor
13 Mar 2012 09:17 #35422 by Ads1987
By the way, what oil type goes in the axles?
13 Mar 2012 10:33 - 13 Mar 2012 10:51 #35426 by dirtydogz
M13AA manual
Type Quantity Specification
Engine Oil 4.0 litres10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.1 litres 75W - 90
Transfer Box Oil API GL-4 0.8 litres 75W - 90
Differential Oil (Front)
API GL-5 1.1 litres 80W - 90
Differential Oil (Rear) API GL-5 1.3 litres 80W - 90
Coolant Capacity 4.5 litres
A/T Fluid/Power Steering Dextron IIE 1.1 litres
Brake Fluid DOT3
G13BB manual
Engine Oil 4.5 litres 10W - 30 (UK recommended)
Gearbox Oil API GL-4 1.3 litres 75W - 90
Transfer Box Oil API GL-4 0.9 litres 75W - 90
API GL-5 1.35 litres 80W - 90
Differential Oil (Rear) API GL-5 1.5 litres 80W - 90
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 13 Mar 2012 10:51 by dirtydogz.
  • Ads1987
  • Visitor
  • Visitor
13 Mar 2012 13:39 #35442 by Ads1987
Brilliant, thanks for the info, i've got the parts on order so will see how it all goes :)
Time to create page: 0.138 seconds
