Swivel leak but no play?
  • Ads1987
  • Visitor
  • Visitor
11 Mar 2012 18:45 #35303 by Ads1987
Swivel leak but no play? was created by Ads1987
Hi everyone,
I've just brought a w reg jimny to replace my defender, it's currently got big Kaiman malatesta mud tyres on that vibrate like hell. I've already found a replacement set but the front drivers swivel has ejected a load of grease and oil everywhere, Ive already read the how to guides etc and it's a very similar build to the defenders. My question is that I don't seem to have any play when jacking up and wobbling the wheels, so could the rough tyres have just vibrated the half shaft seal ? Or would you guys just suggest changing the king pin and wheel bearings a long with swivel seals etc?
Thanks!
  • wanderinstar
  • Visitor
  • Visitor
11 Mar 2012 20:32 #35312 by wanderinstar
Replied by wanderinstar on topic Re: Swivel leak but no play?
Personally, if it was me, I would change the Kingpin bearings as the cost is minimal. You may as well do it as you will have taken the axle in bits anyway to change the drive-shaft seal.
  • Ads1987
  • Visitor
  • Visitor
11 Mar 2012 21:43 #35323 by Ads1987
Replied by Ads1987 on topic Re: Swivel leak but no play?
do you think the main wheel bearings will need replacing? I suppose it just makes sense to do them anyway?
  • wanderinstar
  • Visitor
  • Visitor
12 Mar 2012 09:11 #35340 by wanderinstar
No I wouldnt, That necessitates removal of a large nut that you need a special tool for. Just stick withh changing the kingpin bearings. The bottom one will probably be like the bottom onr in this picture.
  • doncarlyon
  • Visitor
  • Visitor
12 Mar 2012 11:26 #35350 by doncarlyon
Replied by doncarlyon on topic Re: Swivel leak but no play?
If you only have vertical play, then chances are the wheel bearing will be ok.
  • Ads1987
  • Visitor
  • Visitor
12 Mar 2012 16:28 #35363 by Ads1987
Can you change the king pin bearings easily without having the bearing removal tool then?
Cheers guys
Time to create page: 0.171 seconds
