Anti Roll Bar Disconnects
- X-Eng Simon
- Visitor
02 Feb 2012 09:28 #32449
by X-Eng Simon
Anti Roll Bar Disconnects was created by X-Eng Simon
I've thought of a really simple way of making these (hopefully commercially).
It's an alternative to the pin-sleeve arrangement commonly used on Jeeps except one less likely to become jammed with mud and which won't require the vehicle to be absolutely level to lock / unlock.
Do any of you have a photograph of a standard, un-lifted Jimny looking at the side of the axle with the wheel removed which shows the end of the stock anti roll bar and knuckle (the bit wiht the ball joint on either end)?
What I need to see is how much space there is around the anti roll bar on a standard vehicle.
My Jimny when I bought it had a body lift, longer springs and no anti roll bars fitted - so is not an ideal candidate to measure.
If this particular solution works, they could be really good value and easy to make!
Thanks in advance.
Si
Thanks in advance.
Si
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
02 Feb 2012 16:38 #32469
by funkyjimny
Replied by funkyjimny on topic Re: Anti Roll Bar Disconnects
Where's Martin when you need him, he's got a standard jimny sat on the Drive !
Gary
Gary
- supergaz
- Visitor
02 Feb 2012 20:10 #32491
by supergaz
Replied by supergaz on topic Re: Anti Roll Bar Disconnects
I remember once seeing some for the pajero rear anti roll bar drop links with a sleeve set-up, just cannot find any atm. I nearly did get them once for my old pajero, but never got around to it.
02 Feb 2012 20:34 #32495
Replied by mlines on topic Re: Anti Roll Bar Disconnects
Yes, one unmodified Jimmy on the drive. However its dark and cold at the moment!
Sent from my HP Touch pad running Android and Tapatalk
03 Feb 2012 15:39 #32559
Here you go...
Attachment sized_IMGA0590.JPG not found
Attachment sized_IMGA0591.JPG not found
Attachment sized_IMGA0594.JPG not found
Attachment sized_IMGA0595.JPG not found
Attachment sized_IMGA0596.JPG not found
Attachment sized_IMGA0597.JPG not found
Attachment sized_IMGA0598.JPG not found
Attachment sized_IMGA0599.JPG not found
- bluejimny
- Visitor
03 Feb 2012 18:38 #32571
by bluejimny
Replied by bluejimny on topic Re: Anti Roll Bar Disconnects
i haven't seen one of those for a while :laugh: :laugh:
Time to create page: 0.154 seconds
