Fitting a plastic bullbar
  • goatboy
  • Visitor
  • Visitor
16 Mar 2011 07:31 #13462 by goatboy
Replied by goatboy on topic Re: Fitting a plastic bullbar
George 147 wrote: Black plastic piece stays in place. L brackets fit to chassis and protrudes through existing bumper and new bar attaches to the other end. You should have had 3x plastic spacer tubes with it two longer ones and a shorter one. These go in between the new bull bar and the existing bodywork up in under the front of the vehicle three holes at the rear of the bull bar. the short tube goes in the middle. Hope this helps.
Thanks George!
So it sounds like I have to cut the existing bumper then to get the L brackets on? Do they go forward from the chassis through the front of the bumper? (no obvious holes on anything on the bull bar which is confusing me).
I didn't get any spacers but thats easy to fix...
  • George 147
  • Visitor
  • Visitor
16 Mar 2011 21:05 #13485 by George 147
Replied by George 147 on topic Re: Fitting a plastic bullbar
on the black plastic part at the bottom of the bumper you will see it is attached by 3x screws in the center and a 10mm headed bolt at each end these are the two bolts the brackets attach to and protrude forward with the flat at the top. the bull bar should have two holes about 6 x 2 inches long and within these there should be two holes to bolt the other end of the bracket to.
  • goatboy
  • Visitor
  • Visitor
17 Mar 2011 07:19 #13497 by goatboy
George you are a star!
Thanks!
  • Skinhead
  • Visitor
  • Visitor
28 Feb 2012 17:42 #34423 by Skinhead
Replied by Skinhead on topic Re: Fitting a plastic bullbar
Are they easy to steal off another jimny? Sorry i have no job or no money and my jimny is standard!
  • goatboy
  • Visitor
  • Visitor
28 Feb 2012 19:16 #34438 by goatboy
Well I'm glad I don't live near you... :dry:
  • blakey2000
  • Visitor
  • Visitor
28 Feb 2012 20:43 #34449 by blakey2000
Replied by blakey2000 on topic Re: Fitting a plastic bullbar
what year is your jimny, that bullbar with the brackets is off a 2005-now jimny, if yours is an older jimny with the older shape bumper it proably wont have thoes brackets as the bumpers are different.
but thoes brackets go onto the chassis and on to the black part of the bumper. should be 3 holes in the middle of the black part one center and 2 either side of it, at like 10-30cm away either side
bolts onto the chassis on the flat protuding part of the bumper.
