How high is your clutch? (JB74)
05 Sep 2022 19:12 #244872 by 300bhpton
Just wondering for those with 5 speed manuals. How high is the bite point on your clutch?
I’m sure mine has got higher recently. Going to take it into the dealers next week. But thought I’d ask and see what others are experiencing.
For reference mine has just ticked over 17,000 miles (so pretty low mileage still). Is 2.5 years old. I have a tow bar, but it has only towed one 600kg trailer once. I don’t trail or slip the clutch (my Land Rover 90 has 152,000 miles on the original clutch).
05 Sep 2022 19:20 #244874 by Lambert
Dunno what it's supposed to be but on my last one which I had changed at about a hundred and eight odd thousand miles it was the finger springs that were getting tired not the friction material wearing away. Are they still cable operated?
05 Sep 2022 19:40 #244876 by fordem
The clutch on a JB74 is hydraulic, and on my 2021 the bite point is quite close to the floor, maybe 25% of the travel or a little less, and very similar to that on my older Grand Vitara.
As far as I'm aware they are self adjusting (like the Grand Vitara), and as they wear the bite point will get closer to the floor - it's not a linear decrease, but, one day you'll suddenly realize that you have the pedal right against the floor and the slightest movement allows the car to creep - at that point it's time for a replacement.
Looking at the parts catalog, the bellhousing end of things is very similar to the Grand Vitara, the master cylinder end however is very different
05 Sep 2022 20:06 #244879 by 300bhpton
Umm that’s very interesting if true.
In the case of mine it seems to be the opposite. The bite point now seems to be in the last 20-25% of the pedal travel, just before you take your foot off of it. I’m sure it wasn’t like it previously (had it since new).
05 Sep 2022 20:19 #244880 by lightning
Maybe try bleeding the clutch hydraulics
06 Sep 2022 02:51 #244882 by fordem
I'm not going to say don't bleed it, BUT, the reason you bleed a hydraulic system is to remove trapped air, and if there is trapped air, the end result is going to be increased pedal travel so the bite point will be lower down, not higher up.
06 Sep 2022 07:44 #244884 by 300bhpton
Thanks. But as it is under warranty, I don't intend on doing anything to 'fix' it myself.
Time to create page: 0.150 seconds
