Heavy power steering
- Score
- Visitor
19 Aug 2022 11:31 #244601
by Score
Heavy power steering was created by Score
Hello guys ,I feel my steering is too much heavy is this normanl for jimny Gen3 ?And the other problem when i turn my steering uneven lock to lock steering as shown in the video .
youtube.com/shorts/X7Grf54rgD8?feature=share
- Thank you received: 493
19 Aug 2022 11:39 #244603
Replied by DrRobin on topic Heavy power steering
The power steering on my Gen3 is about the lightest I have had on a car in all my years on the road, so much so I had to fit a steering damper, just to make it feel more like a normal car, so suspect you have a problem.
2 days after I bought the car, it sprang a leak in the fluid system on the steering and it then went very heavy (had to use two hands on one side of the wheel to make a slow speed tight turn), so I had to take it back to the garage where they installed a lot of new plumbing. I knew it was the fluid which was leaking as a small pool developed under the front.
Perhaps your has a leak? That or it is the pump. Is the belt and pump turning and belt not slipping?
Robin
Robin
- Score
- Visitor
19 Aug 2022 11:52 #244604
by Score
Replied by Score on topic Heavy power steering
Hello Drrobin
Thanks for your advice that mean i have a serious problem ?
There is no leak at all and no sound from the belt or the pulley .
But when you turn the steering in idle rpm i feel that the fluid is not moving .
For me since i bought this car used and the steering is heavy i thought its heavy becaus a small car 4x4 safety requirements so it will not flip .
- Score
- Visitor
19 Aug 2022 11:55 #244606
by Score
And regarding the uneven lock to c
Lock steering ?
When i turn it to left it turn 1.5 turn and to the right 2 turns .
Is it also because of the power steering problem ?
Lock steering ?
19 Aug 2022 13:00 #244607
Unfortunately I don't know too much about the steering, someone on here will know, but
Lock to Lock - uneven
If there is a difference in the number of turns centre to lock then it sounds like the steering rods have been very badly adjusted, such that with the wheels straight the steering box is not in the middle. Is the steering wheel the right way up when the wheels are straight?
There is another possibility, something is stopping the wheels from turning to full lock in one direction. Is the turning circle the same in both locks?
Heavy Steering
I suspect that the uneven number of turns and the heavy steering are not the same problem. The power [assisted] steering, just helps the steering box move, so either the power steering is not working correctly (weak pump, leaking switch unit or inefficient actuator) or there is some drag on the steering box, that the power steering can't overcome the friction.
A couple of quick questions
- Are you running on standard sized wheels and tyres?
- Do you have a lot of front end weight?
- Does it turn in one direction easier than the other?
- Are the Kingpin bearings seized?
- Does it turn easier if you jack the front of the car up?
Hopefully someone else will jump in who has a better idea than me.
Heavy Steering
- Score
- Visitor
19 Aug 2022 13:58 #244610
by Score
Lock to lock .
The steering wheel is straight and recently i made alignment but still the same .
And yes i feel like there is something blocking me from turning fully to left.
No it doesn't turn the same left is wider than right and that because of less turn it can make to the left.
Heavy steering .
Since there is no leak i suspect the pump .
Q&A
American racing r15 225 25psi stock shocks and coil over.
No same as brand new gen3
Yes, it turn easier to the right than left.
Yes and already the shims installed.
Didnt try this yet
Heavy steering .
Q&A
Didnt try this yet
- Score
- Visitor
20 Aug 2022 07:30 #244640
by Score
Hello robin
This video the car jacked up
youtube.com/shorts/8ybzu827ae4?feature=share
This video the car is down on the ground
- Thank you received: 1814
20 Aug 2022 07:53 #244641
Replied by Lambert on topic Heavy power steering
Either the steering wheel has been moved relative to the steering column eg removed and replaced in a different orientation or the same has been done to the pitman arm on the steering box. It is possible in either case to realign the steering using the drag link but it will then put the steering box into part of its throw that has less wear so it will feel heavier. Another option is that someone has attempted to remove excess play from the steering box using the preload adjustment and set it too high but that would more likely be excessive resistance at the limit of throw in both directions evenly.
20 Aug 2022 07:57 #244642
by Busta
Replied by Busta on topic Heavy power steering
You need to adjust the drag link ( the steering bar in front of the axle) so you are getting the same number of turns in both directions. This will put the steering wheel out of line, so you will need to remove and re-fit the steering wheel so it is straight.
There is an adjustment screw on top of the steering box which is used to take out any slack. It may be that somebody has adjusted this too tight making the steering heavy.
- Score
- Visitor
21 Aug 2022 08:02 #244664
by Score
thanks busta and lambert
you guys are amazing oki i didnt solve the problem but i put my hand on it.
so here what happen i removed the drag link from the pitman arm and the steering wheel turn 2 and little more to left and same as to the right.
but when i connect it with the pitman arm it will make the same problem 1 and half to left and 2 and little more to the right .
and yeah now the steering wheel is not straight at all it need to refit and remove but before that what do you recommend my next step will be to fix my turning issue?
21 Aug 2022 13:28 #244666
If with the drag link removed the steering wheel has even movement side to side then it is the pitman arm that needs to be observed in its movement arc. It should mirror the steering wheel and be even side to side. Assuming that the centre point of the pitman arm matches the straight ahead position of the steering wheel you should not need to touch either. It's worth noting that the steering wheel has a thing called a clock spring in it to transfer signals to the horn and airbag and this is prone to damage if over extended in either direction if the wheel is reindexed too far from its central position on the steering column. With the pitman arm in the middle of it's travel, next set the road wheels straight ahead and then adjust the drag link so that it sits easily into the taper on the pitman arm without moving the pitman arm from its centre rest point.. it's all just rods and pivot points it's not hard to get it set right with a bit of patience.
21 Aug 2022 15:32 #244670
by Busta
I'm now wondering if you might have a broken CV joint that is stopping the wheel turning fully one way, or perhaps and issue with a kingpin bearing binding. With the pitman arm off and the front wheels off the ground steer the wheels by hand and see if there is resistance. The wheel should steer soothly with a consistent amount of force.
