Sell your bits!
Suzuki jimny R72 gearbox
- Greakking972
09 Aug 2022 03:09 #244458
by Greakking972
Suzuki jimny R72 gearbox was created by Greakking972
Good day guys I’m currently in need of a R72 gearbox or one that would fit similarly on a 2009 Suzuki jimny jb43.
09 Aug 2022 19:21 #244468
by Busta
Replied by Busta on topic Suzuki jimny R72 gearbox
R72s are generally expensive and troublesome. You can fit the R7ME from an earlier Jimny with one small adapter for the rear mount. The ratios are 30% longer, which isn't necessarily a problem if you are on standard tyres and drive slow. Otherwise you need to swap the transfer case and diffs as well.
10 Aug 2022 06:13 - 10 Aug 2022 06:15 #244472
Replied by yakuza on topic Suzuki jimny R72 gearbox
R72 newer than 2010 or so are less troublesome. They have upgraded bearings.
Any used R72 gearbox from a VVT Jimny should be a straight fit to your car, but i would choose newer and check if a new used box have the bearings inside with the closed sides.
My 2005 box failed and now i got a 2013 gearbox. stuck a camera in the new box and found green sides on the bearings so they are the upgraded closed ones.
I got 17% high range reduction in my transfer case. It is too much reduction to compensate for my 235's in my opinion as I have the M16 too.
Last time i checked on grim jeeper I found the car would be useless for me if i put a 2004 gearbox from a non VVT in it.
5-6000rpm on the highway if i remember it correctly.
Last edit: 10 Aug 2022 06:15 by yakuza.
10 Aug 2022 20:46 #244495
by Busta
You've got the gearing the wrong way around. The earlier gearbox has 30% longer ratios, so you'll be doing 30% lower rpm at highway speeds.
- Greakking972
14 Aug 2022 12:16 #244534
by Greakking972
Replied by Greakking972 on topic Suzuki jimny R72 gearbox
Ok np I’ll continue to search for this gear box although I think I’ve exhausted my options.
I was thinking wherever of not other vehicles Carries the gearbox as mine to just replace since it’s not available
14 Aug 2022 17:23 #244536
by Busta
Every manual Jimny from 2005 to 2018 uses the same R72 gearbox, but it's not found in any other vehicles.
16 Aug 2022 09:43 - 16 Aug 2022 09:48 #244543
>Busta post=244495
>You've got the gearing the wrong way around. The earlier gearbox has 30% >longer ratios, so you'll be doing 30% lower rpm at highway speeds.
ok, not used to the term "longer" as higher or lower is only used in my profession.
I just knew it has the "wrong" ratios.
I must be confusing it with the vvt/auto transfer swap result from grimjeeper.
Last edit: 16 Aug 2022 09:48 by yakuza.
Time to create page: 0.143 seconds
