More first world problems, weight Vs tunes?
- Thank you received: 1839
08 Jul 2022 20:30 #244011
Replied by Lambert on topic More first world problems, weight Vs tunes?
If I'm being honest I could probably loose 20 kg myself and not really notice. But that's mission creep and I'm not going there. The weight is not so much the removable items like fuel or EDC it's more the fixed things which a speaker system is. Hence the reluctance to go mad with the armour plate under the car. Having said that though there has been a bit of a move towards using trailers ever more frequently as a result of moving to the fixed towbar, it's less of a faff to hook up which is good as it means less running solo at or near gvm.
In case it's not apparent I over think things and like to consider every eventuality before I change what I'm doing. Like I said, not normal.
09 Jul 2022 07:09 #244015
by Busta
Replied by Busta on topic More first world problems, weight Vs tunes?
I'm all for keeping things as light as possible, but I've always made an exception for speakers. I recently read about someone advocating ditching the spare wheel to unlock extra performance and improve fuel economy. I'm highly sceptical that such small differences can be noticed. My fuel economy baely changes when I'm towing over a ton.
So I say go for it!
So I say go for it!
06 Aug 2022 11:40 #244415
Today I have been mostly putting bass blocker capacitors in my front speaker feeds. This is instead of trying to get more 165mm cones in under the dashboard as that would be a lot of work. The caps are slightly on the high side at .8 micro farrad this means a cut off about 2khz, around 6 to 8 farrad would be better at around 300hz, but they are what I have and more importantly the fronts are only 100mm cones so it's not too bad. It means that I can fade forward again and allow the DSO to lift the sound stage out of the foot well for the higher range which makes it sound better. Obviously all the bass from the 165mm's that I installed on the front support legs of the plywood rear deck last weekend and the under seat sub is all focused on my lower spine but feeling bass in your bum is not the worst thing in the world. On the whole it's starting to sound like a fairly competent system now, it makes passers by look up anyway.
- redoregan
- Visitor
07 Aug 2022 15:28 #244433
by redoregan
Replied by redoregan on topic More first world problems, weight Vs tunes?
Haha so true.Historically I have always had fully amped systems in cars that weren't for work and have only in recent years of Jimny moved to a high power head unit because of the space constraints. What I also have difficulty with is the local Tarquin brigade in daddies amarok being able to drown my none standard system, I find it an affront to my masculinity
09 Aug 2022 10:26 - 09 Aug 2022 10:27 #244460
Replied by yakuza on topic More first world problems, weight Vs tunes?
I still think that all my efforts to change the speakers in the original positions to gain some sound that could pass as being sufficient was futile. I removed the small pockets on the door sides that was not doing any much at keeping my car tidy anyways, and replaced them with a sheet of MDF and a front speaker set from Focal. (i think it was) Did the full sound mat insulation inside the door as well.
After a while we allways want more of course.
Next up was the rear door that is around 20 liters and again full sound mat insulation inside and out. replaced the inner door trim with again a sheet or three of MDF. An old amp from when i was young(er) drives the 8" Subwoofer from Ground Zero. My head unit got a pre amp out for subwoofer that can be adjusted for low pass. I will have to do the insulation again because the amount of air that blows out of the door handle makes the sound a bit unprecise and outside it sounds like a complete failure.
But inside is not bad at all and way better than anything i ever did to replace the original speakers.
I also do feel a bit masculine when cranking up actually, allthough my younger colleagues just laugh as they should
Just realized I will need to post pictures of the speaker boxes now..
Last edit: 09 Aug 2022 10:27 by yakuza.
Time to create page: 0.137 seconds
