31.5” Gen 4 Jimny
- Thank you received: 1839
Might be worth getting in touch with him (not sure of his tyre size off hand) but his videos are well worth a watch. His next mod is to tackle the gearing.
www.youtube.com/channel/UClku6Tqzh8MvUcoMCpl8gUA
- Blacksails
- Visitor
Lambert wrote: Ok so if it's not been regeared then that is not ideal but not a deal breaker. What it means is that the torque converter will heating the transmission fluid up more than a standard car but this can be compensated with an additional oil cooler. The thing is though the standard car is designed to tow a 1300kg trailer without placing undue heat stress on the transmission. By running the larger tyres you are in essence working the transmission as if it's got a trailer on all the time so the reality is likely that with just the big tyres you will be fine if however you need to tow a trailer as well this will need additional transmission fluid cooling. Hope that makes sense and isn't too rambling.
Yes, this makes sense and wasn't to rambling, unlike my original post. Thank you! I don't intend to be doing any towing at any point so that shouldn't be an issue
- Blacksails
- Visitor
I wasn't aware of this, no. Ah, this is good to see. I will drop him a message, thanks.Soeley wrote: Are you familar with this guy on YouTube?
- Blacksails
- Visitor
