Which lift ORA or other?
  • supergaz
  • Visitor
  • Visitor
22 Jan 2012 17:36 #31562 by supergaz
Replied by supergaz on topic Re: Which lift ORA or other?
Look at the small box below the bottom of the bonnet.
Full 3 or 4.5suspension kit for £1000 + Value Added Theft + Postage.
www.offroad-armoury.com/
  • jimny5
  • Visitor
  • Visitor
22 Jan 2012 21:55 #31615 by jimny5
Replied by jimny5 on topic Re: Which lift ORA or other?
It was coming up at top of screen, any suspension kit for 1000 plus vat and 15% off every thing else. Code ny deal.
  • Dutchjimny
  • Visitor
  • Visitor
23 Jan 2012 17:44 #31656 by Dutchjimny
Replied by Dutchjimny on topic Re: Which lift ORA or other?
no shit thats a good deal there
23 Jan 2012 18:21 #31662 by funkyjimny
I have a 3" lift, from jimnybits, and some ORA front arms, Rob Storr Panhads and steering rod etc. someone mentioned that a 3" lift kit isnt enough for 31's ? I run 750/16's which are near enough 32", jimnys are tippy enough without jacking them up to 4.5". Each to their own, obviously if you want it to look like a monster truck then get the highest you can, personally I think 2" lift is enough and cut the arches out a bit, and cut a chunk out of the bodymount under the front headlights , keeps C of G as low as possible, my tyres dont rub anywhere.
Just my opinion for what its worth, but Ive had a few jimnys over the last 7 years.
Gary
  • g187eev
  • Visitor
  • Visitor
23 Jan 2012 18:42 #31666 by g187eev
Replied by g187eev on topic Re: Which lift ORA or other?
If you have the right off-set to make up for the lift, there is no reason why your Jimny will be unstable. If fact a well set-up Jimny with a 4.5" lift and good off-set will actually feel more stable than stock.
With a 4.5" lift and say 31" tyres I would recommend 8J rims or 7J with 30mm spacers.
RB
  • Dutchjimny
  • Visitor
  • Visitor
23 Jan 2012 18:52 #31668 by Dutchjimny
Hi Rob,
A little offtopic but im getting youre 3"lift installed next week, i was just wondering does it need 32mm wheelspacers? for better handling? and do i need to raise my brake balancer?
Thank you!
Stefan
  • darthloachie
  • Visitor
  • Visitor
24 Jan 2012 08:53 #31712 by darthloachie
Replied by darthloachie on topic Re: Which lift ORA or other?
when you lift the jimny you raise the centre of gravity making it more prone to tipping over on a sudden evasive manouver - fitting spacers increases the track of the vehicle and helps to offset the higher centre of gravity
yes you should also raise the brake balancer to keep the brake balance consistant
  • Dutchjimny
  • Visitor
  • Visitor
24 Jan 2012 15:02 #31730 by Dutchjimny
hmm i dont have that bracket.. but it seems easy to make can anyone give me the height measurement>?
About the spacers.. will see how it handles first my 235 is already slightly sticking out of the arches
  • darthloachie
  • Visitor
  • Visitor
24 Jan 2012 16:12 #31739 by darthloachie
same height as your lift :)
Time to create page: 0.134 seconds
