KAP exhaust
- adam
- Visitor
I did put an extra couple of layers of black high heat spray on just to help the life time of it.
It would of gone on perfect if I hadnt left on the bracket from the real bull bar, had to grind that off as the bolts werent playing ball!!!
End of the day, its a great can with a roaring raw sound. Not too loud and not to quiet, just enough to make your jeep a little meaner.
stop teasing ...................
we're all picture junkies and you can't say things like "roaring raw sound" and not put a video up
- adamatdraycott
- Visitor
I emailed KAP a couple of months ago, but no reply
My standard factory exhaust has started to rattle when cold... i assume its the heat shield... its been flaking since i had the car 18months ago
Any info would be appreciated
- adam
- Visitor
- Johnniehec
- Thank you received: 56
adamatdraycott wrote: My standard factory exhaust has started to rattle when cold... i assume its the heat shield... its been flaking since i had the car 18months ago
Very tinny rattle at idle or accelerating is likely to be the heat sheild on top of the cat the four corners of mine rusted off leaving it completely loose but it can't fall off cos of the lambda sensor. I put a bit of stainless steel "band it" "make your own jubilee clip" round the whole thing to stop the rattle.
John.
- Adamski
- Visitor
Mine is also rattling, it has flaked away really badly on the outside and when I tap it I can hear the inside rattling badly. I'm going to go the custom route using the middle section of an exhaust from another car as the back box on the Jimny (gives it a nice exhaust note), and I can make it fit with my tow bar.
Out of interest, what is the bore of the kap back box? I'm thinking of going for 2".
It would be great if you could get a video of the kap box up
- ZookFastback
- Visitor
Hope this attachment works as I haven't had much luck with uploading sound from my Linux system
- renard38
- Visitor
- ZookFastback
- Visitor
- ZookFastback
- Visitor
- doncarlyon
- Visitor
- adam
- Visitor
