fuel saving /power booster
  • anth69y
  • Visitor
  • Visitor
16 Aug 2011 20:14 #20508 by anth69y
fuel saving /power booster was created by anth69y
hi everyone
just wondered if any of you good people have fitted a fuel /power boost chip like this
www.tuningwizard.co.uk/index.php?main_pa...119&products_id=2254
if so what do you think ,do they improve power or fuel consumption like they state or do they bugger up your jimny ?
  • mark1971
  • Visitor
  • Visitor
17 Aug 2011 03:57 #20518 by mark1971
Replied by mark1971 on topic Re: fuel saving /power booster
My mate built his own, it's just a potentiometer that makes the ecu think the inlet temp is colder than it actually is and let's more fuel into the mix. 40 bhp is quite an exaggeration in my opinion. Not sure of the long term effects it could have on the engine, I always file these away in the drawer marked urban myth along with those fuel saving magnets that attach to the fuel lines.
  • Az1987
  • Visitor
  • Visitor
17 Aug 2011 04:42 #20520 by Az1987
Replied by Az1987 on topic Re: fuel saving /power booster
As said above they work by tricking your engine ECU in to thinking the air going in to the engine is cooler than it is, so the ECU then up's the fuel. So all they do is make you car run rich all the time which will make you use more fuel and could poss damage the CAT as more fuel in the system means more undurnt fuel in the exhaust and higher emissions come MOT time.
17 Aug 2011 06:51 #20527 by ooky_123
you need some snake oil too ....
Former owner of Little "Ooky", who has now started a new life in Shetland
17 Aug 2011 10:37 #20539 by facade
I had the opposite idea on the rangerover (with flapper air meter: I forget the code number)
I put a resistor in parallel with the engine temp sensor to fool it into thinking the engine was warmer to back the choke off and save fuel, as well as stopping it hunting at idle.
A jimny has an exhaust gas sensor that will trim the fuel when running at a steady speed and negate any fiddling with air temperature sensor.
  • anth69y
  • Visitor
  • Visitor
17 Aug 2011 15:18 #20554 by anth69y
Replied by anth69y on topic Re: fuel saving /power booster
that was more the idea not to get more power but to get better mpg ,its a great little plodder which i am happy just pottering around in but if i can improve fuel consumption that would be a bonus .
i wondered if any jimny owner had improved there mpg in any way or if it was as good as it gets from the factory
  • anth69y
  • Visitor
  • Visitor
17 Aug 2011 15:21 #20555 by anth69y
if you squeeze the snake will this help it to emit the oil
17 Aug 2011 17:18 #20572 by facade
To get better mpg:
1) Fit road tyres, blow them up hard to reduce sidewall flexing.
2) Don't go above 50mph- ever :)
3) Try not to press the brake or accelerator down at all, plan the route so you can switch off* and arrive at your destination just as the wheels stop turning.
4) Get behind a large vehicle, and drive as close as possible to get a little bit of a tow from his slipstream (this can be frowned upon by people in uniforms, some nonsense about thinking distance :dry: )
5) Use 5w30, 10w30 or straight 30 weight oil in the engine, instead of 10w40.
6) Make sure the air cleaner is clean and the plugs are in good condition.
7) Keep the windows shut.
8) Keep the battery topped up with an optimate,and don't use anything electrical (heater fan, lights, radio etc.)
* there is no point coasting in neutral with the engine on, this uses more fuel to keep it ticking over than letting it overrun when the engine will cut the fuel off
I use numbers 1,2,3,6,7 & 8 regularly and get about 33 mpg out of my twin cam.
  • darthloachie
  • Visitor
  • Visitor
17 Aug 2011 17:38 #20575 by darthloachie
Replied by darthloachie on topic Re: fuel saving /power booster
whatever you do - dont do any of these
fit 31" special tracks on steel wheels
fit an external roll cage
fit heavy duty steel bumpers
fit a big front winch
:huh: :ohmy: :cheer: :laugh: :woohoo: :side:
  • supergaz
  • Visitor
  • Visitor
17 Aug 2011 18:20 #20582 by supergaz
Replied by supergaz on topic Re: fuel saving /power booster
darthloachie wrote: whatever you do - dont do any of these
oops! :-) I've done all these!
17 Aug 2011 19:17 #20586 by facade
That reminds me: ;)
9) don't carry any surplus weight- (leave the toolbox at home) easy enough when the boot is so small, you could take the rear seats out and leave them at home as well.
However, there does come a point when the desire to save fuel interferes with the reason you have the jimny in the first place. Suzuki 4x4s are not very economical full stop. If I need to drive 100 miles I use our Corsa, I can get 45mpg on a run and drive at 70mph.
I used to get more MPG from the (diesel) SWB terrrano and about the same from the 200Tdi engined 110 Landrover. (but I do save £100 a year on road tax)
  • anth69y
  • Visitor
  • Visitor
17 Aug 2011 19:53 #20588 by anth69y
kids would kill me if i took the back seats out . i must admit i only bought the jimny for the winter ,well if it goes the same as last year i will be laughing. we have a diesel c4 and it was doing 73.4 mpg when we went to buy the jimny . but last winter i could not pull away from my front door on a flat road and when we did get it moving it was an absolute night mare and i have driven and ridden just about everything and it was the worst
so if the jimny can drive in the snow its worth its weight in gold
Time to create page: 0.223 seconds
