Do Grand Vitara 16" steel wheels fit?
- little jimny
- Visitor
Former owner of Little "Ooky", who has now started a new life in Shetland
- little jimny
- Visitor
The idea behind them is to go to 205/80/16 tyres as they are bigger and easier to get. This is a standard LR size but we have smaller diffs so gain ground clearance over them.
I'm replying on my phone and don't have time to get onto the Pc as I'm working long hours at the moment, so if anyone else can post pictures of the two types it would be useful to you I guess.
- little jimny
- Visitor
- supergaz
- Visitor
- Thank you received: 115
little jimny wrote: would 16" Grand Vitara steel wheels fit straight onto the Jimny with no modifications? I'm sure Martin had refurbed a set, but I don't remember if they were ever fitted to a Jimny...
Where you getting good 16" GV Rims from?
Jalapeño, IISY?
There are always breakers trying to pedal single wheels for £35 each but you don't have to pay that much.
I have bought a couple of sets in the past for £60 for 4 but nowdays I think you can expect to pay up to £100 for 4 or 5 as they are hard to get hold of in good condition.
They are not the B all and end all in Suzuki wheels though -they collect mud alot and have small drain holes between the inside and outside of the centre where it meets the rim which clog and hold mud in them, putting them out of balance where other wheels would have thrown it off.
Also, my 215/80/15 Maltesta Kaimans measure up the same height as a set of 205/80/16 Insa Turbo Special Tracks, so you can get to that size of tyres without changing your wheels.
There are bigger than 205/80/16's that people have fitted to the GV wheels though and that is where the benefits really start to come into their own with these wheels. Of course they require big lifts, alot of body cutting and a rocklobster and will effect your on road speed.
Think hard before you shell out too much on them if you only intend them to be wearing 205/80/16's as a nice set of new modulars can be only £120 ish!
But rims are a bit bashed now, and wanted to know if you knew where i might get some more ??
I'm more than like putting on new tyres soon and getting these fitted - inner arches will need changing somewhat ... but they give me an extra inch in height!
Jalapeño, IISY?
- little jimny
- Visitor
As Kirkynut says you can find them on eBay. I found a set on there, also the same set listed on gumtree. They looked in good nick (as you can see from the picture I posted), but if I'm going to have to sort out a set of spacers to get them to fit they're no longer such a cheap option.maverick wrote:
little jimny wrote: it's these ones I'm looking at
Yeah, I've seen those on eBay - they're about as 'dinted' as mine are!!
16" rims and 16" tyres dfinittely help the raising of the Jimny .. I already have arches and flare cut back - i suspect the new 16/750's will rub on the inner/lower arch (where foot-well is) ... so its either the BFH and/or some slitting/cutting with Mr. A. Grinder and weld-up the seams afterwards!
I have 'borrowed' a 16/750 Tyre of a mate who is doing the same, and his spare wheel. My objective is to see how much i need to BFH/cut back ... before i go out and buy 5 for myself!!
Jalapeño, IISY?
