Fitting a spare wheel to the Bonnet
  • teafortwo0789
  • Visitor
  • Visitor
31 Jul 2011 17:28 #19771 by teafortwo0789
Fitting a spare wheel to the Bonnet was created by teafortwo0789
I'm considering the feasibility of locating a spare wheel on my Jimny Bonnet, similar to Landrover Defenders.
However there are some problems as I see it.
1. Wheels are very heavy, I'm sure the bonnet will need strengthening.
The question is how? I was thinking of a couple of bars running north to south in the engine bay, with a Jimny spare wheel bracket attached. A hole could be cut in the bonnet through which the wheel could sit
2. The wheels are quite 'thick' so I think the wheel will significantly impact forward vision. By siting the wheel through the bonnet I may gain a couple of inches vertically and improve forward vision.
I'm trying to balance the car for weight distribution. However the end result must be very strong to cope with a long and very rough journey.
Any suggestions most welcome.B)
  • ZookFastback
  • Visitor
  • Visitor
31 Jul 2011 17:42 #19773 by ZookFastback
Replied by ZookFastback on topic Re: Fitting a spare wheel to the Bonnet
I'd prefer to put a puncture repair kit in the boot ;)
31 Jul 2011 18:26 #19779 by mlines
What you need is this bodyshell...
Attachment sized_suzukijimny004.jpg not found
Attachment sized_suzukijimny003.jpg not found
Attachment sized_suzukijimny002.jpg not found
31 Jul 2011 18:27 - 31 Jul 2011 18:28 #19780 by facade
teafortwo0789 wrote: I'm trying to balance the car for weight distribution.
Mount it behind the seats like a SWB Landrover.
I remember moving the spare from the bonnet to the tub when off roading my series because the other boys reckoned that it was better for weight distribution.
And I dont think the feeble jimny bonnet hinges will take the weight either. ;)
Last edit: 31 Jul 2011 18:28 by facade.
  • supergaz
  • Visitor
  • Visitor
31 Jul 2011 18:41 #19781 by supergaz
Replied by supergaz on topic Re: Fitting a spare wheel to the Bonnet
mlines wrote: What you need is this bodyshell...
I remember seeing that on e'bay, thinking what? why? :huh:
  • bari
  • Visitor
  • Visitor
31 Jul 2011 18:54 #19783 by bari
  • little jimny
  • Visitor
  • Visitor
31 Jul 2011 19:25 - 31 Jul 2011 19:26 #19784 by little jimny
Replied by little jimny on topic Re: Fitting a spare wheel to the Bonnet
teafortwo0789 wrote: I'm considering the feasibility of locating a spare wheel on my Jimny Bonnet, ...... I'm trying to balance the car for weight distribution.
The Jimny feels nose heavy to me, especially when I ran mine without the spare wheel for a week. If your aim is to balance the car for weight distribution I think that taking the spare off the very back of the car to put it over the front wheels is going against your stated aim.
It would like cool though B)
Last edit: 31 Jul 2011 19:26 by little jimny.
  • SPC5838
  • Visitor
  • Visitor
31 Jul 2011 21:38 #19785 by SPC5838
Replied by SPC5838 on topic Re: Fitting a spare wheel to the Bonnet
My bonnet rattles on the catch with the weight of four foglights... :(
  • teafortwo0789
  • Visitor
  • Visitor
01 Aug 2011 13:36 #19795 by teafortwo0789
Replied by teafortwo0789 on topic Re: Fitting a spare wheel to the Bonnet
Thank you all.
My problem is I need to carry 2 spare wheels for my Mongol trip 18k miles. I'm considering a 6 point roll cage so I can attach the wheels to the side of the cage. Similar to Martins 'special body'.
That will leave the rear door to store water cans or jerry cans. However I'm seeking to keep the overall weight down, and the roll cage will add a lot of weight ! I don't want to store wheels on the roof as that would raise the centre of gravity too much and inside will eat up too much space. Back to the drawing board..................................
01 Aug 2011 14:50 #19797 by Johnniehec
I was going to suggest this, it's amazing what you can find on Google,
Attachment borneo-safari-suzuki-jimny-sj410.jpg not found
but I see you want to carry two, back to that body shell on ebay! (does anyone know who bought it?) seriously though if you're thinking of mounting on either side what about a single loop style roll bar and mount them to either side that way?
The following user(s) said Thank You: teafortwo0789
01 Aug 2011 14:59 #19798 by Johnniehec
I've just had another idea. fit an offset bracket like the one in my photo to make room for the jerry can/s and fit the other to the bonnet. I don't think it's a bad idea, don't know what "Plod" in the UK might think. I liked your idea of strengthening bars accross the engine bay but rather than cut a hole in the bonnet I'd mount the carrier on the bonnet, probably on a spreader plate, and fix it to the bars with heavy duty bonnet pins so you could still open the bonnet (It'd be bl***y heavy though).
01 Aug 2011 19:09 #19815 by mcjimny
I'd look at strengthening the bonnet in some way too and use a pair of strong gas struts to help with lifting it.
