4.5 lift
- unsure
- Visitor
24 Jul 2011 13:35 #19439
by unsure
4.5 lift was created by unsure
Hi,
anyone got pics of the ORA 4.5 lift kit on yours? also what size tyres you squeezed in??
cheers
joe
o and anyone running 70 series axles?
cheers
joe
- renard38
- Visitor
24 Jul 2011 15:56 #19443
by renard38
Replied by renard38 on topic Re: 4.5 lift
my friend adrix has 235-75-15 BF KM2
- unsure
- Visitor
24 Jul 2011 18:12 #19451
by unsure
Replied by unsure on topic Re: 4.5 lift
any pics?
i am fitting 70 series axles planning with ORA 4.5 lift kit and running 33's.
would like to see how they fit....
cheers
cheers
- Mud_Muppet
- Elite Member
- Thank you received: 7
25 Jul 2011 16:35 #19494
by Mud_Muppet
2001 Red Tin Top,
4.5 inch ORA lift kit,
Pro Comp steering damper
Kap Winch Bumper,
White Weller offset Rims with 30" Insa Turbo Special Tracks,
CB Radio,
Stripped Interia
Roof Rack with 4 front Wipac,
Rear Wipac recovery Lights
.....Plenty more on its way !!!!
Replied by Mud_Muppet on topic Re: 4.5 lift
would like to see some pics aswell, im planning on fitting this kit soon, but only running 31inch tyres
2001 Red Tin Top,
Kap Winch Bumper,
CB Radio,
Stripped Interia
- Blakey
- Visitor
25 Jul 2011 16:37 #19495
by Blakey
Replied by Blakey on topic Re: 4.5 lift
You should be able to get 33" on with ease or bigger depending on how much you want to cut away of the arches and inner arches. Theres this one
www.bigjimny.com/index.php?option=com_ku...amp;limitstart=12
cant see what size tyres are on it but they look bigger than normal.
hope this helps
hope this helps
- darthloachie
- Visitor
25 Jul 2011 16:56 #19497
by darthloachie
Replied by darthloachie on topic Re: 4.5 lift
have a look at this one
www.bigjimny.com/index.php?option=com_ku...6&id=15659&Itemid=75
- unsure
- Visitor
25 Jul 2011 18:41 #19506
by unsure
looks like i need a body lift too then.....
may pick one up at the same time, unless anyone knows i can get away without one....
and i dont mind trimming the arches at all, even planning on shifting the front axle forwards a little bits.
cheers again
guys
cheers again
guys
- darthloachie
- Visitor
25 Jul 2011 19:32 #19509
by darthloachie
think you'll need a body lift as well
we have a 4-5" ish lift on ours and the 31" special tracks will touch inside the rear arches on full flex
would like to fit 33s on ours but will need to put a body lift on and that will mean having the roll cage lifted as well !
- unsure
- Visitor
25 Jul 2011 20:07 #19510
by unsure
ok, cheers for the reply, i will pick a bodylift up whilst i am down there on weds.
Shoudl be quite a good truck once done, a hell of alot lighter than my landy anyway.
Will need a cage etc eventually but i will get some pics and do progress pics too.
Dont think running inner arches will be an issue as even without offset wheels they should sit 5inches out on each side with the cruiser axles...
cheers again
cheers again
- darthloachie
- Visitor
26 Jul 2011 07:15 #19525
by darthloachie
sorry - mean on the inside of the outer wheel arches - they've been popped out so mant times they are now self tappered and cabled tied into place :dry:
- unsure
- Visitor
26 Jul 2011 19:29 #19546
by unsure
lol, sure i will sort something out. will sort pics soon, collecting all ORA bits 2mo afternoon so it shall begin.
getting axles mounted is priority
- Matmobile
- Visitor
28 Aug 2011 01:22 #20961
by Matmobile
Replied by Matmobile on topic Re: 4.5 lift
Attachment t_jimny_04.jpg not found
Attachment t_jimny_06.jpg not found
Time to create page: 0.178 seconds
