lift and wheel spacers
  • Keefe
  • Visitor
  • Visitor
18 Jul 2011 20:01 #19154 by Keefe
Replied by Keefe on topic Re: lift and wheel spacers
No wheel spacers are fitted at all, I don't use them.
When I bought (got mugged) the Jim, I was told that they were Rhino Rays offset steel wheels.
I don't know the measurements of the wheel offset but if you wanted, you could try to ring Ray on 01273 696796 and ask him what his are, or email him:
mail@rhinorays.co.uk
Just trying to help.... :)
19 Jul 2011 05:34 - 19 Jul 2011 07:04 #19160 by dirtydogz
Hi nicho
Halford has 32mm wheel spacers on standard alloys so i think the tyres will sit level with the arches.
As for the lift if your not using it for a lot of off roading then spring spacers are your best bet.
The spring spacers i use are made of polyurethane and are not the hard rubber spacers so the ride is not that hard.
www.bigjimny.com/index.php?option=com_ku...8&id=10688&Itemid=75
So if you go for the spring spacers buy the poly spacer kit for BITS4 VITS or email martin at BIG JIMNY
www.bits4vits.co.uk/store/jimny/1-5-jimn...n-lift/prod_395.html
Hope This helps
DIRTYDOGZ B)
www.bigjimny.com/index.php?option=com_ku...8&id=17232&Itemid=75
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 19 Jul 2011 07:04 by dirtydogz.
  • nicho
  • Visitor
  • Visitor
19 Jul 2011 14:49 - 19 Jul 2011 14:53 #19184 by nicho
Replied by nicho on topic Re: lift and wheel spacers
hi halford now has at2s on same size as ours wich gives us a chance to see what they are like with wheel spacers , hoping halford decides now to get the 1.5 inch lift kit : ) cant praise the 75mm at2s enuf.thanks kefee going to emale him now
Last edit: 19 Jul 2011 14:53 by nicho. Reason: missed sumet
Time to create page: 0.144 seconds
