lift and wheel spacers
- nicho
- Visitor
16 Jul 2011 03:54 #19025
by nicho
lift and wheel spacers was created by nicho
hi im thinking of doing a 1.5 inch lift and wheel spacers has any one got any pics from the rear to see what the hight and track looks like ,we have 205 75 15s on steel wheels,thanks
18 Jul 2011 08:28 - 18 Jul 2011 08:43 #19107
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: lift and wheel spacers
Hi nicho
I have 1.5 spring spacers with 205/75/15 +7x15 moduiars big jimny rear shock spacers.
hope this helps
DIRTYDOGZ
hope this helps
DIRTYDOGZ
2002 JLX Soft Top
Last edit: 18 Jul 2011 08:43 by dirtydogz.
- nicho
- Visitor
18 Jul 2011 10:22 #19112
by nicho
Replied by nicho on topic Re: lift and wheel spacers
thanks for the pics yeah they are great,my next question was going to be about modulars and off sets insted of using spacers which i would prefer,would like them to look the same as what are on now but stick out further like 30mm or 25mm spacers,any ideas of where to get them from,i think i read somewere that some one on here sells them.
18 Jul 2011 15:36 - 18 Jul 2011 15:37 #19125
by mcjimny
Replied by mcjimny on topic Re: lift and wheel spacers
Dave sells them - bits4vits -
www.bits4vits.co.uk/store/wheel-spacers/nuts/cat_40.html
Last edit: 18 Jul 2011 15:37 by mcjimny.
- Keefe
- Visitor
18 Jul 2011 16:11 - 18 Jul 2011 16:13 #19127
by Keefe
Replied by Keefe on topic Re: lift and wheel spacers
If you're wanting the offset wheels, I think Rhino Ray still does them.
I have them on mine and in my mind, much better than spacers, especially the hollow cast ones. (In my opinion, others like them?)
www.rhinorays.co.uk/wheels.htm
£35 each.
Widens track by 90mm.
K
£35 each.
K
Last edit: 18 Jul 2011 16:13 by Keefe.
- nicho
- Visitor
18 Jul 2011 17:11 #19132
by nicho
Keefe have you got any pics that show the whole of jimny , ive had a look and only found the ones on my jimny that shows pics close up, would love to see what it looks like with 90mm,
- nicho
- Visitor
18 Jul 2011 17:20 #19134
by nicho
dirtydogz this may sound daft but are your wheels off set,im thinking if ther not that would mean you have the extra width equeled out eather side of a standard rim,but yours look offset
- nicho
- Visitor
18 Jul 2011 17:31 #19140
by nicho
and on the lift side of things for 1.5 inch is ther any kits for not much more money than lifting with spring spacers etc,and are they any good,just wondering wether its worth spending a bit more then it doesnt give a harder ride as people have reported after fitting spacers.
- Keefe
- Visitor
18 Jul 2011 18:53 - 18 Jul 2011 18:56 #19148
by Keefe
These are all I have at the moment from when I first bought it.
It has a 2" spring lift and 205/75R15 Recip Trial Tyres.
I can't get newer pics yet as the Jim is in one or two bits in a 'tight for space' garage at the moment.
Tyres are just about level with the edge of the wheel arches, as in very little of the tyre 'sticks out'.
hth
K
hth
K
Last edit: 18 Jul 2011 18:56 by Keefe. Reason: picture +d
18 Jul 2011 18:55 #19149
by dirtydogz
2002 JLX Soft Top
My wheels have a 20mm offset.
spring spacer are a eco lift.
You will need to buy a 2" lift kit from jimnybits.
www.jimnybits.co.uk/shop/jimny/jimny-2-/...lift-kit/prod_1.html
2002 JLX Soft Top
- nicho
- Visitor
18 Jul 2011 19:41 - 18 Jul 2011 20:01 #19152
by nicho
Keefe do you have wheel spacers on in them pictures or are they just the offset wheels which you sead were 90mm extra track.
Last edit: 18 Jul 2011 20:01 by nicho. Reason: missed sumet out
- nicho
- Visitor
18 Jul 2011 19:48 - 18 Jul 2011 19:53 #19153
by nicho
dirtydogz am i right in thinking then if i got 32mm wheel spacers and used our standard rims they wouldt stick out past arches as much as yours.thanks for all the info by the way every one trying to get things right first time around to save £
Last edit: 18 Jul 2011 19:53 by nicho. Reason: missed something out
Time to create page: 0.188 seconds
