Springs
  • shootinginger@yahoo.co.uk
  • Visitor
  • Visitor
28 Mar 2011 08:05 #14168 by shootinginger@yahoo.co.uk
Springs was created by shootinginger@yahoo.co.uk
will vitara +2 inch springs fit a jimny?
  • panosd
  • Visitor
  • Visitor
28 Mar 2011 10:26 #14173 by panosd
Replied by panosd on topic Re: Springs
Only the rear springs of vitara fits at jimny.
And you might need a teflon spring spacer at front to correct
the front lean of the car because all 4 springs you are going to fit have the same height.
  • Visitor
  • Visitor
28 Mar 2011 10:34 #14175 by shootinginger@yahoo.co.uk
Replied by shootinginger@yahoo.co.uk on topic Re: Springs
O right, what's the reason why the fronts dOnt fit? I rake it it's the drivers side front that needs the spacer ?
  • vitara_mad
  • Visitor
  • Visitor
28 Mar 2011 12:02 #14180 by vitara_mad
Replied by vitara_mad on topic Re: Springs
if vitara rear springs fit what about using some rover 600 rear springs as they are used on the rear of vits to give a 3" lift ????
  • biggaz
  • Visitor
  • Visitor
28 Mar 2011 15:07 #14186 by biggaz
Replied by biggaz on topic Re: Springs
what about weight difference between vit and jimny? is there much as this may affect the ride!
  • Visitor
  • Visitor
28 Mar 2011 17:33 #14191 by shootinginger@yahoo.co.uk
i can see the springs on vitara's being stronger/take more weight, bigger engine, and bigger in size, but as for the rover 600 springs, they may be softer.
so you wreckon the rover 600 springs will fit a jimny and lift by 3"? why wont they fit the front?
  • srcars
  • Visitor
  • Visitor
28 Mar 2011 18:22 #14204 by srcars
Replied by srcars on topic Re: Springs
shootinginger@yahoo.co.uk wrote: i can see the springs on vitara's being stronger/take more weight, bigger engine, and bigger in size, but as for the rover 600 springs, they may be softer.
Have a search on google or e-bay for vitara front shocks and you will see they are a completely different design to the jimny. The Vitara has a front strut (shock/spring combined) as opposed to the jimnys seperate spring/shock set up.
Rich
28 Mar 2011 18:49 #14210 by mcjimny
Replied by mcjimny on topic Re: Springs
biggaz wrote: what about weight difference between vit and jimny? is there much as this may affect the ride!
Other than GV's the vitara should be very similar in weight, remember the Jimny is a bit lardy for a small car at 1000kg+
If you're after a cheap lift and find the rover springs do fit the rear you can buy just 2 spring spacers from dave(bits4vits).
  • Visitor
  • Visitor
28 Mar 2011 18:49 #14211 by shootinginger@yahoo.co.uk
o right thnaks, well if the rover 600 rear springs can be used, i might see if i can get 2 pairs and use them!
  • panosd
  • Visitor
  • Visitor
28 Mar 2011 19:05 #14213 by panosd
The front vitara springs have bigger diameter than jimnys one. So they dont fit to the pattern.
The 600 rover springs are not for 3''.
What we use in Greece is a set of 4 rear springs from XL7 for 3'' lift
or most common at the competition setup jimnys 4 rear springs from the calmini kit of 3'' for vitara
which give a real 4'' lift.
The best combination is 4 rear calmini springs from the 3'' vitara kit with Hotbits shocks.
Worth's every one euro that you spend to buy them. This is going to be my next setup.
  • vitara_mad
  • Visitor
  • Visitor
28 Mar 2011 21:51 #14219 by vitara_mad
rover 600 rear springs do give a 3" lift to the rear of a vitara so if the calmini 3" rear springs from vitara works on the jimny then i dont see why the rovers won't do the job
its worth a try
  • panosd
  • Visitor
  • Visitor
29 Mar 2011 11:05 #14229 by panosd
It wont give a 3'' because the 3'' calmini for vitara have more spirals.
But yes if you can find them cheap we dont make a try.
I have 4 rear lada samara springs witch gave me 4'' lift. :laugh:
Time to create page: 0.207 seconds
