Air conditioning retrofit
Revision as of 18:10, 24 February 2019 by Gadget (talk | contribs) (All Gen4 Jimnys have A/C as standard, removing Gen4 tag)
If your vehicle already has air conditioning installed from the factory, you don't really need to read this article. Just read the chapter "Benefits of having air conditioning" and enjoy life.
If you don't have air conditioning, you might consider installing it, either by buying a ready-to-fit kit from Suzuki, or by transplanting all the required parts from a dead Jimny in a local vehicle junkyard.
  1. It cools and dehumidifies the air on hot weather (obviously).
  2. It rapidly demists foggy front window and front side windows during cold or humid weather, even when you set the air conditioning to heating mode.
  3. It can provide additional significant engine braking power when descending very steep hills, either on road or off road.
Since Jimnys have relatively small engines, the engine braking assistance of the air conditioning is significant indeed. In other words, the air conditioning soaks up a relatively large percentage of energy which the engine has to handle. This "air conditioning braking" skill needs some technique to master, because you need to time it right with the on-off operation of the air conditioning compressor.
Buying an entire OEM kit
  • If you want it to be simple and professional, Suzuki does sell complete OEM air conditioning kits for Jimnys which don't have air conditioning system installed from the factory.
    • A kit contains all the required parts (and there are a lot of small parts).
    • Beware that the prices for these kits are very high (four digits in EUR currency).
  • The needed kit depends on your Jimny edition and revision.
    • The table below contains data sourced from several OEM parts catalogues.
      • However, it is best to consult with your local Suzuki dealer to avoid any costly mismatches.
OEM A.C. retrofit kits for Jimnys gen3
Air conditioning system retrofit kits - Jimny gen3
P.N. Applicable
model
Additional notes
95000-81A10-000 Type 1 For gasoline engine G13BB (59 kW);
95000-81A70-000 Type 2-4 For gasoline engine M13A (60 kW) with lever operated 4WD controls;
95000-81AB0-000 Type 5-6 For gasoline engine M13A VVT (63 kW) with button operated 4WD controls;
It appears that this set has been replaced by 95000-81AF0-000;
95000-81AD0-000 Type 7 For gasoline engine M13A VVT (63 kW) with button operated 4WD controls;
95000-81AF0-000 Type 5-12 For gasoline engine M13A VVT (63 kW) with button operated 4WD controls;
(It is stated in some brochures from early 2012 that this set is only for Jimnys type 9,
but it is stated in later brochures that it is for all gasoline Jimnys from type 5 onward);
95000-84A00-000 Type 4 For diesel engine K9K 700 (48 kW) with lever operated 4WD controls and power assisted steering;
95000-84A01-000 Type 5 For diesel engine K9K 700 (48 kW) with button operated 4WD controls and power assisted steering;
95000-84A10-000 Type 6-7 For diesel engine K9K 266 (63 kW) with button operated 4WD controls and power assisted steering;
Transplanting air conditioning system from another Jimny
It isn't yet known of anyone who has actually performed a DIY air conditioning system transplantation from one Jimny to another.
Therefore, the actual details on what all the parts to transplant (and how) are unknown. Be the first one to try it and report your experience here.
Page last edited on 24/02/2019 by user Gadget
