Front brake pad change
Revision as of 13:57, 21 February 2019 by Bosanek (talk | contribs) (Category adjustment)
Changing the Brake Pads is a simple and quick job within the grasp of most people's abilities.
The symptoms of worn brake pads:
  • Poor braking
  • Pulling to one side
  • Squealing and judder when braking
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A G-Clamp or piston retraction tool
Removing the Caliper and pads
Jimny Front Caliper
  • First of all secure the car.
  • Release the wheel nuts and jack up the car and remove the road wheel.
  • This then reveals the brake caliper, this is the passenger side (nearside) caliper (UK) .
Unbolting the caliper
Open brake caliper
Removing the brake pads
  • If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips).
The new pads
  • Here are the new pads compared with the old.
  • Note that ADK84224 are an aftermarket equivalent of the Suzuki part.
  • New pads, are available in the BigJimny Store.
  • The old are worn down to the metal.
OOPS!
The new pads fitted
  • The new pads then simply push into place held by the spring clips.
  • Place the anti-squeal shims in place.
  • Smear a bit of Copper Grease on the rear of the shims to help reduce squeal.
Using a G-Clamp
  • Now the Piston has to be moved back.
  • I use a G-Clamp and wind the piston back in until it is flush.
  • Pay attention to your brake fluid reservoir during compression as this will drive brake fluid back through the lines and can cause your reservoir to overflow.
All done
  • Now swing the caliper back into position and bolt up the caliper bolt.
