Multimedia player upgrade or replacement
Revision as of 10:08, 21 February 2019 by Bosanek (talk | contribs) (Added a new link)
Note Icon.pngThis article is just an embryo. It is an idea for someone to "pick up" onto and to expand the article further.
Note Icon.pngThe wiki article "Accessories for Jimny (genuine Suzuki)" contains vast info and details on many OEM Jimny accessories, including a dedicated section on various officially compatible multimedia players and corresponding mounting kits (look in the section "Interior infotainment").
Installing a 1-DIN multimedia player
  • An OEM mounting kit for a single DIN multimedia device, P.N. 990E0-59J55-000;
  • An OEM screw to install a single DIN radio, P.N. 990E0-59J55-SCR;
    • Four pieces are needed;
In both cases, a suitable wiring connector adapter appears to be required:
  • For Jimnys type 1-2: OEM P.N. 00800-71016-MIC;
  • For Jimnys type 3-12: OEM P.N. 00800-71017-MIC;
Installing a 2-DIN multimedia player
  • As far as it is known, Suzuki has not predicted that anyone would install an aftermarket 2-DIN multimedia player in a pre-2005 Jimny (with original old interior design).
    • Therefore no known official solutions or mounting kits exist for such combination, and it is not known how that endeavor will end up regarding physical and electrical fitment and dash board trim alignment.
      • Report your experiences here!
  • Installing an aftermarket 2-DIN multimedia player in a post-2005 Jimny (with revised interior design) is definitely and officially achievable.
    • However, the replacement options are a bit complicated / expensive.
      • Reason: The dimensions of the hole in the center console trim in which it sits are not standard.
      • Therefore, if you install some aftermarket 2-DIN device, it will probably fit in the hole, but the trim around it will not be aligned.
        • There will be some empty non-trim space around the device.
    • Kits (surrounds) exist which fill the void around the aftermarket 2-DIN CD players, both genuine kits from Suzuki and aftermarket Chinese-made kits.
  • Read the wiki article on genuine accessories (linked above) to find out what exact bits and pieces are additionally required (it depends on vehicle edition and if it has previously had a radio player installed from the factory or not).
  • Here is one practical solution.
  • Most Jimnys with revised interior design (produced between 2005 and 2018) have a factory-installed 2-DIN-alike Clarion radio-CD player (typically installed from cca 2005 onwards).
    • That Clarion player can only play audio CDs, and is quite fussy about which ones it accepts.
    • That player fits perfectly in the hole in the center dash board trim because it is not a standard 2-DIN format - it is custom-made for Jimnys.
  • It is possible to install almost any 2-DIN multimedia player ina Jimny with revised interior design, but additional bits and pieces are needed for proper fitment, and possibly a wiring connector adapter.
  • Here is an installation report from a German guy on installing a Kenwood DDX5015DAB multimedia unit.
Expanding the multimedia capabilities of a Clarion player
Instead of replacing the factory Clarion 2-DIN alike music player, it is quite possible (and relatively cheap) to significantly expand its capabilities:
  • There is an aftermarket add-on Chinese device Yatour YT-M06, which enables simple and intuitive MP3/WMA playback from an SD card, USB stick etc. directly through the Clarion player.
    • Yatour YT-M06 can also be optionally upgraded with a Bluetooth handsfree kit Yatour YT-BTM, which then works seamlessly with a Clarion player (answering calls, hearing the other speaker on vehicle speakers, ending calls, etc.).
  • Yatour YT-M06 has been proven to work quite reliably in practice, in various temperature and humidity conditions.
  • It also works quite intuitively - MP3/WMA music files are played in an identical manner like selecting CD tracks on a Clarion CD player.
  • Caution when buying: Yatour YT-M06 exists in several editions (for various car brands / factory radio systems).
    • The editions which are compatible with Jimnys (Clarion CE-NET radio system) are YTM06-CLAR and YTM06-SUZ1.
      • Both editions are identical - they are just named differently depending on a seller.
Note Icon.pngA Jimny owner from Brazil wrote a very good "how to" installation guide for installing Yatour YT-M06 add-on to a Clarion radio.
