- 1 Introduction
- 2 1. Tyre size
- 3 2. Tyre model
- 4 3. Five identical tyres
- 5 4. Tyre pressures
- 6 5. Underbody protection guards
- 7 6. Underbody rust protection
- 8 7. Tie rod ends
- 9 8. Steering damper (shock absorber)
- 10 9. Transmission breathers
- 11 10. Fluids
- 12 11. Lifting the vehicle
- 13 12. Deep mud and water terrain
- 14 13. Recovery points
- 15 14. Front bumper issue
- 16 15. Mud flaps
- 17 16. Rear wheel inner arch mounts
- 18 17. Side window wind deflectors
- 19 18. Differential housings
- 20 19. Sound system (player)
- 21 20. Sound system (speakers)
- 22 21. Increasing cargo space
A Jimny in factory stock form is quite capable vehicle for all terrain use, and "okay" for on-road use (depending on your on-road needs and preferences).
However, as every vehicle, it has its weak points and potential for improvement in areas where the manufacturer skimped (or made an oversight) during design or construction phase.
Also, there are some improvements and modifications which go "beyond" the vehicle's mechanical design "contours", but they make a significant improvement for certain usages.
Jimnys can be extensively modified to the extent of being unrecognizable, but the expense will be twice as much as a brand new Jimny, and the vehicle will be no good for anything except for rolling in the mud or over rocks.
However, if the vehicle needs to be used in mixed conditions (on road, city, highway, job, family, and all kinds of all terrain use), the goal is just to improve it and modify it "sensibly" - while staying within the legal boundaries and within the logical/practical usage boundaries that will satisfy all of those usage conditions.
In accordance with that mixed usage criteria, here are the most common points of improvement and modification for Jimnys (in no particular order of importance):
1. Tyre size
An entire encyclopedia can be written on tyre sizes. However, if you want larger tyres, but just want a quick and simple solution without complications and projects, use tyres in size 205/75/R15.
That is the best "sensible" upgrade to the factory size of 205/70/R15 - it gives you the most gain for the least amount of vehicle modifications required, and virtually no degradation of driving parameters. If you have a 2nd gen. front bumper (see below), you might have to straighten it if it is sagged, or trim it just slightly (invisibly) on the bottom. Also, if you have front mud flaps, you might have to trim a plastic spacer behind them by approx 10 mm. And that's all that might be needed. It's both dead simple to do.
2. Tyre model
Another encyclopedia can be written about proper tyre models. However, for general mixed use, a simple and satisfactory solution is a good all-season AT class tyre model.
Two tyre models with which people have had great experiences on Jimnys are Goodyear Wrangler AT/SA+ and General Grabber AT (not AT2!). Also, General has recently (09/2016) released model AT3, which looks very interesting. Avoid the model AT2, it is very old and deprecated one! There are other tyre brands and models of course.
Here is Bosanek's list of all brand-name HT, AT and MT tyre models which he has found on the market: docs.google.com/spreadsheets/d/1jFMegEyy...ml?gid=1&single=true
A lot of time has been spent populating that list, and adding custom remarks there. The list is still incomplete in some details, but will be updated from time to time.
Note: Not all of those tyre models are available in sizes which are compatible for Jimny.
Buy and use five same (identical) tyres! The spare tyre should not sit idle all the time! That is even written in Jimny's owner manual.
The spare tyre should be actively rotated with the other four. In case of an all-terrain vehicle like the Jimny, that gives you so much benefits, and only one downside - you pay 25% more at once.
Here is Bosanek's document which shows the rotation scheme: docs.google.com/spreadsheets/d/1svFOPe-Z...ml?gid=0&single=true
Here is Bosanek's document which lists "FOR" and "AGAINST" reasons to actively use all five identical tyres in a 5-tyre rotation scheme: docs.google.com/spreadsheets/d/1svFOPe-Z...ml?gid=0&single=true
Is is a handy practice to rotate the tyres with every motor oil change. If you recently bought a set of four new identical tyres (they have not got worn more than 1-2 mm at most), you still have plenty of time to buy the fifth one (you don't need it yet, until the first rotation).
Warning: If you have a hard or soft spare wheel cover, you won't be able to use it with a spare tyre which is larger than the stock size.
4. Tyre pressures
Learn the skills of tyre pressure management. Changing your tyre pressures to suit the (off)road conditions is the most effective vehicle mod ever! The benefit is not just for improved traction, but also for improved ride comfort and reduced vehicle stress!
In general terms, reducing tyre pressure by 20-30% from stock on-road pressure is the operating norm for hard gravel and general off-road conditions. For deep mud, deep snow, sand and other boggy conditions, even more pressure reduction can be used (but with caution).
So, for a Jimny, the stock tyre pressure is 1,6 bar front and 1,8 bar rear (some people even it to 1,7 bar on all four tyres). When driving on gravel roads or general off road, it is OK to reduce the tyre pressure by 25-30% to 1,25-1,15 bar - the difference in ride quality is astonishing, while the traction is significantly improved.
Install aftermarket-made metal guards for the radius arm mounts, the transfer box and the rear shock absorbers. They will pay of with VAT the first time they get hit!
Coat the underbody of the vehicle with good anti-rust material (bitumen).
7. Tie rod ends
It is recommended to use original tie-rod ends. If you are using Jimny off road, these will prove much more durable than aftermarket ones. Since you need to pay for wheel alignment after each tie-rod end change, it definitely pays off to use the best ones - OEM!
This is one area where you can do a good deed to your vehicle, no matter where you drive it.
All serious all terrain vehicles have factory installed steering dampers. Suzuki's vehicles do not, although they need it badly because they are so bumpy and twitchy. Suzuki probably skimped on that for cost reasons.
If you install a steering damper, it will significantly improve the steering feel. The steering in a Jimny is generally very light. With a steering damper, it will feel heavier in a positive sense (like you are driving a proper big 4WD vehicle), but will not be hard.
Also, vehicle's "twitchy" behavior at dodgy tarmac roads will be significantly softened, and the shake while driving on gravel roads will be significantly cushioned.
There are several steering dampers available around, which can be utilized on a Jimny. If you don't want anything flashy, the ordinary steering damper made for Land Rover Discovery 1 (Armstrong STC786) has been found to be quite satisfactory, and is cheap to buy online.
Since Jimny has no mounts for the steering damper, there are several "bolt on" kits available to buy, but you can also weld on your own pieces of metal to make the mounts if you have that skill and do not mind to "burn" the vehicle.
Jimnys axles and transfer box have small caps which serve air breathers which allow air to come in if the oil inside cools (and contracts) rapidly (for example when the vehicle dips into deep mud or water). However, there is a risk of that mud or water coming inside through those breathers, fouling the oil and causing expensive damage.
Therefore, it is very advisable to at least install extended front and rear axle breathers. The "extended breathers" are nothing more than rubber hoses! They are dead simple to install. Installing them on a transfer case is more complicated (the transfer case should be dismounted first), and there is a much lower risk of it getting water over it anyway.
To install extended axle breathers, just buy good quality rubber hose (approx 6-7 m of length) with internal diameter of 1/2", and a few good quality metal screw-tight straps for hoses. Remove factory breather caps from the axle differential housings and put on the rubber hoses, and tighten the metal straps on the connection point. Lay the hoses through the underbody, in the engine bay, up to the bonnet height, avoiding hot surfaces. You do not even strictly need a "T" hose connector for interconnecting the two axles, as each hose can go independently up to the top. Tie the hoses here and there with plastic strap ties, and leave enough extra slack hose near the axles, because the axles move up and down during usage.
During usage, check the hoses now and then in case that they are starting to come off at the axle connection point (you DO NOT want them to separate ).
10. Fluids
If you recently bought the Jimny, change ALL fluids and filters. That means oils in: engine, front axle, rear axle, gearbox, transfer box, power steering, brakes, and the engine coolant. Required oil specifications and quantities are written in owner's manual.
A lot of people dream about lifting their 4WD vehicle, as they consider that a main beneficial mod for off road use. However, the benefit of a lift highly depends on the extent (severity) of off road terrain.
Anyway, lifts come with many disadvantages and costs. They might require extensive modifications of suspension, steering and driveline components. They will make a car more unstable on the road.
Therefore, if you decide to lift the vehicle up, then it would be a good countermeasure to widen its stance (to stabilize it) by installing wheel spacers or using offset rims. For road use, it is not recommended to lift Jimny above 2" or use spacers thicker than 3 cm.
JimnyBits has a 1,5" lift kit which is supposed the be the most "sensible" option (least amount of vehicle modifications required to accomodate the lift), so consider that first.
A stock jimny with no lift nor spacers (apart from 205/75/R15 tyres) can still get to most places where you intend to go, just with more skill or attempts applied (and that's the name of the game).
Although Jimny can be used for deep wading or mud bogs if you install transmission breathers and the snorkel, bear in mind that Jimny has a weakly designed front wheel steering knuckle, which is prone to water/mud ingress, and that damages kingpin bearings, CVs, etc.
It is very hard to prevent water/mud ingress there (use of some hardcore sticky waterproof grease inside can help to deter water and mud, but that's it).
Therefore, it's best to avoid mud bogs and deep water.
If you want to get really filthy on a regular basis, use a Defender, Land Cruiser, Patrol, G-wagen or something else that was 5-10x more expensive than a Jimny when it was new. Or be ready to become a trained expert at working on Jimny's front wheel assembly.
13. Recovery points
If you intend to go off road, there is a good chance that you will get stuck no matter how equipped your vehicle is nor how "sensibly" you intend to venture. Therefore, you should invest in strong recovery points. If you don'n, and the factory recovery point breaks, you will have to use money as a recovery point, but it needs to be a thick stash of bills to endure the load!
Jimny's front tow point is weak, especially if the pulling direction is sideways. It can be VERY dangerous if the recovery point breaks off during pulling, as it becomes a lethal flying missile.
Therefore, it is important to have strong front and rear tow/recovery points, and it is best to have two front and two rear. Unfortunately, there are hardly any professionally manufactured aftermarket recovery points for Jimnys (and Suzuki does not make them). Your best bet is to weld on something of your own design (and your own trust).
When towing/pulling or being towed/pulled, always connect an "equalizer" tow strap to both the left and the right recovery point, as that will divide the load between the two recovery points. Connect the main snatch strap or tow strap to the equalizer strap, and the other vehicle to the main strap. If you use just one recovery point, you double the risk to rip off your recovery point, or bend the chassis arm if the lone recovery point is indeed so strong!
Using omega shackles rated at 3,25 T should be sufficient for Jimny, especially when the load is divided between two recovery points.
Jimnys have been in production since 1998, and there have been tree front bumper models on them - 1st gen. bumper (1998-2005), 2nd gen. bumper (2006-2012) and 3rd gen. bumper (2013-ongoing). The 1st gen bumper is the smallest one (does not hang too low to the ground). The 3rd gen. bumper also is not bad. However, 2nd gen. bumper is overly large (hangs very low to the ground), and it significantly reduces the approach angle - the risk of it hitting the ground is quite higher than with other two bumper models.
Therefore, the 2nd gen front bumper is the most endangered point when off-roading, and it's easy to damage.
Also, 2nd gen. bumper reduces the space around the front wheels, limiting the size to which the wheels can be increased (by using larger tyres). With 2nd gen bumper, the usual limit is 205/75/R15 (and even that size sometimes makes a contact if the bumper is sagged), while with the 1st gen bumper even 215/75/R15 is not a problem.
For all the mentioned reasons, some people trim the 2nd gen. front bumper, but it tends to look ugly. The best alternative is to buy a second-hand 1st gen. front bumper (1998-2005) from a scrap yard, paint it if needed, and install it instead of 2nd or 3rd gen. front bumper (the mounts should be almost 100% compatible - but I have not tried yet).
15. Mud flaps
Consider installing mud flaps, especially if you intend to use wheel spacers or offset wheels - you will spend less money on washing the car (or maybe you like to be dirty).
Just bear in mind that you will have to trim front mud flaps' plastic spacers (between the mud flap and the wheel arch) for 205/75/15 wheels (nothing scary nor complicated). However, front mud flaps will probably have to be removed if you want to use tyre sizes 195/80/R15 or 215/75/R15 (or larger) together with wheel spacers or offset wheels.
Install genuine mud flaps.
If you install rear mud flaps, it is suggested to drill two holes (fi=30 mm) in the bottom of the rear bumper, behind each mud flap. That will enable the mud, which regularly accumulates in the rear bumper behind the mud flaps, to drain off. Otherwise, it is almost impossible to flush out.
In the rear wheel arches, there are metal lips which were meant to be mounts for the inner plastic wheel arch covers. However, as far as I know, Suzuki has never produced those inner plastic wheel arch covers. Therefore, these inner metal lips just accumulate mud and grit above them, which is quite difficult to flush out. Eventually the area will rust.
It is recommended that you either grind these inner metal lips off, or fill the space above them with some filler mass (thick bitumen, silicone, whatever). That will prevent the mud and grit from accumulating in your wheel arches.
Consider installing wind deflectors on the side windows. Very handy items! They reduce wind noise when cruising, and enable you to open the windows a bit even when it is raining.
Original ones are the best fit (and it is a tight fit indeed). Clearances on the top of the doors are really tight for the moving side windows, and you do not want to harden the life of your electric window motors more than you need.
Jimny is one of are vehicles today which has both front and rear solid axles. It is one of the last Mohicans.
Therefore, it deserves some war paint.
Paint your front and rear differential housings in a striking color (yellow, red, green). It will make you smile more often. Beware: kids on the street might think that a ball got stuck under the car.
Factory radio-CD player in Jimny can only play audio CDs, and is quite fussy about which ones it accepts. There is a solution without replacing the factory music player. Installing this simple Chinese-made add-on enables MP3 playback from an SD card, USB stick etc.: www.danbp.org/w/Installing_an_USB/SD/MP3...zuki_Jimny_OEM_Radio It works quite well and is intuitive. You can upgrade it with Bluetooth handsfree if you want.
Jimny has only two weak and dull front speakers. However, it has pre-machined space for a pair of rear speakers as well, as well as part of the wiring for them. If you replace the front speakers with something good, and install a pair of good rear speakers, you will get a significantly improved sound (nothing "boombastic", just solid and proper).
Links: www.danbp.org/w/Upgrading_the_original_s...rom_the_Suzuki_Jimny www.danbp.org/w/Installation_of_the_rear..._on_the_Suzuki_Jimny
If you need more cargo space, buy roof racks and a roof box. Bosanek used Thule "100" ("S") and "200" ("M") size roof boxes on his Jimny.
Thule boxes have several models, but their sizing names are the same across the model range. For example, Ocean 100, Pacific 100, Touring 100, Touring S, Motion S, etc. they are all almost the same size. Sizes 100 and 200 fit great. Size 780 also fits, but looks just a bit bulky. Anything larger than that looks like a boat on the roof.
You can regularly go off road with the roof box on, just bear in mind that your center of gravity is higher with the roof box on (especially with cargo in it). It is important that the box is of high quality so that it can withstand vibration abuse when driving on gravel and off road.
