CV joint replacement
Revision as of 11:46, 5 August 2016 by Mlines (talk | contribs)
Ooo printeradmin.pngPrint this page as a PDF
Changing the CV joint
  • Clicking when in 4WD when turning
  • Banging and snatching of the steering wheel
  • Loss of 4wd
CV joint information
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts market and the other is nearly impossible to source.
  • Type 1: 6 balls, 26 external splines and 19 internal splines. - Easy to source
  • Type 2: 8 balls, 26 external splines and 29 internal splines. - Difficult to source, 6 Ball Jakoparts J2828040 is supposed to fit.
Note: I can get Type 1 for you, I just do not stock it as too many people bought the wrong one and wanted to return it.
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
Splitting the ball joint
undoing the Kingpin bolts
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!. That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
The old bearing race
Removing the bearing race
A simple way to drive them out is to use a 1" Imperial socket. Using an extension bar fed through the swivel place the 1" Socket behind the ring and drive it out by hitting it. (picture from Dave at Bits4Vits
The rebuilt swivel
The greased CV joint
Applying sealant
Page last edited on 5/08/2016 by user Mlines
