Diesel (DDiS) Jimny specifics
Revision as of 11:41, 27 February 2017 by Bosanek (talk | contribs) (Some small wiki code adjustments)
Suzuki used to produce a factory diesel edition of Jimny, primarily for the market of Western Europe (excluding United Kingdom).
The catalogue model name for diesel Jimny edition is JB53. Its technical model name is SN415.
The marketing name for diesel Jimnys is "DDiS".
DDiS Jimnys were most popular in Portugal, Spain, Italy and France. A rough estimation is that almost every second Jimny in those countries, which was sold in the period 2003-2011, was DDiS.
DDiS Jimnys also had minor to moderate presence in several other European countries. Notable examples are Belgium, Germany and Austria. A rough estimation is that two in every ten sold Jimnys in those countries, in the period 2003-2011, were DDiS.
Note: DDiS Jimnys have never been available in United Kingdom.
Since DDiS Jimnys were produced "only" between 2003 and 2011, while petrol Jimnys have been in production since 1998 and still ongoing in 2017, DDiS Jimnys are relatively rare even in Europe.
Therefore, a potential Jimny buyer would normally be concerned what parts for the relatively rare DDiS Jimnys are specific to them, and how difficult is it to obtain those parts. Also, their typical concern is about servicing the diesel engine and other DDiS specifics.
How to spot a DDiS Jimny on the road
  • Every DDiS Jimny has a prominent "power bulge" on its bonnet, which looks like it has been glued to the bonnet.
  • Every DDiS Jimny has (or used to have) a "DDiS" badge on both front wheel fenders, near side turning lights.
  • Diesel engine's sound is easy to recognize due to characteristic diesel "knocking" sound.
If 7th and 8th character in vehicle's VIN are "53", than it's a DDiS edition. This is the proper "official" way of recognizing a DDiS Jimny.
Note: Petrol Jimnys made after 2012 also have bonnet bulge, but it is different than a DDiS bonnet bulge. DDiS bulge is narrower and taller. The post-2012 petrol bulge is much wider and lower.
Both bulges are fake. They are blanked with a black plastic blanking plate, so actually no air passes through them.
A DDiS bulge actually has a technical purpose - to provide some additional space for the top of the 1.5 DCI engine to fit under the bonnet when the bonnet is closed. The intercooler in newer 63 kW DDiS Jimnys has no connection nor relation with the bonnet bulge. The intercooler is positioned low right front, just behind the front bumper.
A post-2012 petrol bulge has no technical purpose. It has only a financial purpose - to increase sales.
DDiS bonnet bulge pictures
Advantages and disadvantages of DDiS versus petrol
Advantages
  • Lower fuel consumption, especially in city driving;
  • Overall fuel consumption is probably the lowest among any proper all-terrain vehicle model ever produced;
  • Much higher torque (pulling power), especially newer DDiS with 63 kW engine;
  • Engine's RPM-torque curve is much more biased towards 1500-2000 RPM range, which is excellent for all-terrain driving;
  • Much better suited for towing;
  • Has a mean looking power bulge on the bonnet, which is different and larger than the power bulge on post-2012 petrol Jimnys;
  • Engine sounds mean and utilitarian, making the vehicle appear/seem like a larger serious 4WD truck both from inside and from outside.
The plentiful torque of the 63 kW diesel engine means that it is much less sensitive to additional load in the vehicle than the petrol engine. For example, the engine still pulls solidly even with four adult passengers inside, a roof box full of bags, four bicycles on the towbar and air conditioning on.
Disadvantages
  • Availability limited to certain European countries, and in most of them it is relatively rare.
  • Not produced after year 2011.
  • The engine weights cca 80-100 kg more, so vehicle's already unbalanced front-to-rear weight distribution is further worsened - slightly increasing vehicle's tendency to oversteer in bends, lose traction on uphill bends, or especially when going uphill in reverse (all this in 2WD mode);
  • The engine is noisier and certainly vibrates more than the petrol, decreasing interior comfort;
  • Higher periodic engine maintenance costs;
  • Generally, diesel engines are much more complex than petrol ones, increasing the overall risk of failures, some of which are very hard to diagnose and/or very expensive to repair;
  • Older 48 kW Renault 1.5 DCI engines are notorious for developing catastrophic engine failures caused by some elements of the fuel supply and distribution/injection system;
  • The overall reliability of Renault's 1.5 DCI diesel engines generally is not quite on the same level as the excellent reliability of Suzuki's M13 petrol engines. But "your mileage may wary" as they say!
  • Vehicle is a half-breed of two completely different vehicle manufacturers. It has Renault's engine and some engine peripherals, with Suzuki's vehicle computer and some engine peripherals. So, if it develops a complicated engine issue, you will be stuck (or stretched) between two sides. Only Suzuki workshops can read and change all genuine failure/diagnostic codes, descriptions and settings, but most of those workshops have no experience and knowledge about Renault's engines. On the other hand, Renault workshops have the best knowledge and experience about servicing Renault engines, but no proper access to vehicle's ECU. You will most probably have to move the vehicle back and forth between those two to completely resolve the issue (if the two sides are that cooperative)!
  • Not great for really hard-core offroading, because the engine was not really designed for such a heavy duty, and because turbocharger works only above cca 1500 RPM (standard turbocharger "turbolag" issue);
  • If frequent short-term stopping/pausing while offroading is performed (for example to take pictures etc.), the engine should not be turned off because turbocharger needs cooling down first (standard turbocharger issue);
  • The table below presents fuel consumption figures for DDiS Jimnys.
  • For comparison, fuel consumption figures for petrol Jimnys are also presented.
Fuel consumption figures [l / 100 km]
K9K 700 diesel
1461 cm3
48 kW / 65 HP
K9K 266 diesel
1461 cm3
63 kW / 86 HP
G13BB petrol
1298 cm3
59 kW / 80 HP
M13A petrol
1328 cm3
60 kW / 82 HP
M13A VVT petrol
1328 cm3
63 kW / 86 HP
Urban 7,0 7,0 10,2 9,5 9,3
Extra-urban 5,6 5,6 7,1 6,8 6,3
Combined 6,1 6,1 8,2 7,8 7,3
Data source Suzuki brochure Suzuki brochure www.mobile.de www.mobile.de Suzuki brochure
Notes:
  • Mobile.de usually sources the fuel consumption data from vehicle manufacturers, but there are no guarantees about the accuracy.
  • The fuel consumption statements are the same for both the older 48 kW DDiS engine and for the newer 63 kW DDiS engine. This is not an error.
  • All stated fuel consumption figures are for vehicles with manual gearbox.
  • All stated fuel consumption figures are " ideal / official / laboratory / etc." figures, which might not be accurate in real life (just like for any other vehicle).
  • With AT-class tyres, the vehicle consumes about 6,2 l / 100 km extra-urban and about 7,5-8,5 l / 100 km urban.
  • Note: I rarely drive solely in urban areas between two fuel tank fills, so I can not give an accurate figure about urban fuel consumption.
  • With a roof box on the roof, the fuel consumption increases by circa 0,5 l / 100 km.
  • On difficult gravel roads and off road terrain, fuel consumption varies widely based on the conditions. It is typically around 8-11 l / 100 km, but it can be as high as 15 l / 100 km in severe conditions.
  • The overall average fuel consumption after 30 000 km of all roads, terrains and conditions is 7,3 l / 100 km. This figure might vary significantly for other people, based on what, on what, through what, with what, without what, where, how, with who and without who they drive.
DDiS generations
  • The 1st generation corresponds to "Type 4" Jimny technical revision;
  • The "1.5th" generation corresponds to "Type 5" Jimny technical revision;
  • The 2nd generation corresponds to "Type 6" and "Type 7" Jimny technical revision;
  • The 1st DDiS model was produced from 2003 until the first part of 2005.
  • The 1.5th DDiS model was produced for a short while in 2005.
  • The 2nd DDiS model was produced from the end of 2005 until approx 2011. The second model had several minor revisions. The differences between types 6 and 7 are generally minor.
The change from 1st to 2nd DDiS model occurred at the same time period when all Jimnys (both petrol and diesel) changed from manually operated 4WD transfer box to electrically operated (push-button) transfer box and from 1st generation interior trim to 2nd generation interior trim and from 1st generation front bumper to 2nd generation front bumper. This transition occurred during the second half of 2005.
  1. Change of engine from 48 kW (65 HP) to 63 kW (86 HP) by the addition of an intercooler.
  2. Different fuel injection system;
  3. Different fuel filter;
  4. Different electrical generator and alternator (not verified yet);
  5. Different air conditioning system and piping (not verified yet);
  6. Different turbo charger;
  7. Different engine sensors (crankshaft, camshaft, lambda, etc.) (not verified yet);
  8. Different engine cooling system and piping;
  9. Different ECU (vehicle computer);
  10. Change from manually (lever) shifted transfer box to electrically (push-button) shifted transfer box;
  11. Possibly a different gearbox?
  12. Change from 1st generation to 2nd generation front bumper (see wiki article "Front bumper issues");
  13. Completely redesigned interior trim (dashboard, instrument panel, steering wheel, switches and dials, seats, etc.);
The summary of the changes in the engine bay is that, while the basic engine block might have remained the same, most of the peripheral engine components have changed, and an intercooler was added. This resulted in significant power and torque increase (from 160 Nm to 200 Nm). Fuel consumption remained the same (see the subchapter "Advantages and disadvantages of DDiS versus petrol" for details on fuel consumption).
The change from 1st to 2nd DDiS model also contains many common technical changes which happened with petrol Jimnys during the same transitional period. Examples are different CV joints, front brake discs and front brake pads, handbrake cables, external side mirrors, etc.).
The newer intercooled 63 kW DCI engine requires the use of 2nd generation front bumper (to accommodate the intercooler and to feed it with air). That is why the 2nd generation front bumper was invented in the first place, but Suzuki sadly decided to bolt it onto every petrol Jimny as well from 2006 until 2012.
Additional notes
All DDiS Jimnys with the older 48 kW (non-intercooled) engine should be avoided like the plague! The reason is a notorious catastrophic engine failure, which commonly develops in those engines. It is a common issue with those Renault engines which are found in many other vehicle models from the era of 2003-2005 (Clio for example). In short, a poorly made high pressure fuel pump starts to create metal particles, which then quickly destroy fuel injectors and even engine cylinders. The result is a total engine write-off.
There have been numerous reports of exactly that problem plaguing DDiS Jimnys with 48 kW 1.5 DCI engine. There have also been several success stories of such Jimnys achieving more than 200 000 kilometers on the odometer without a problem. But why gamble, especially when 48 kW is severely underpowered?
  1. To have a smaller 1st generation front bumper (see wiki article "Front bumper issues");
  2. To have a manually (lever) shifting transfer box;
Newer 2nd generation DDiS Jimnys with 63 kW 1.5 DCI engines have different fuel injection system components which typically do not suffer from the above mentioned catastrophic failures. They also have significantly more power and torque than the 1st generation DDiS Jimnys, while retaining the same (or even better) fuel consumption.
Notes on factories
There used to be widespread belief that DDiS Jimnys were made exclusively by Santana in Spain. However, there have been several confirmed findings of DDiS Jimnys which were made in Japan (VINs beginning with "JSA...."). Also, Suzuki's official service manuals clearly mention VIN ranges for DDIS Jimnys which are made in Japan, and contain a lot of servicing information for them. All Jimnys built by Santana have their own different service manuals.
It would be recommended to buy a "made in Japan" DDiS Jimny purely because Santana built Jimnys tend to have a mix of different parts and configurations without some particular rule. Adding that variety to the existing variety of having a DDiS in the first place might be a little bit too much of varieties.
Notes on DDiS engines
General information
Both the older 48 kW and newer 63 kW "DDiS" engines are (more or less) ordinary Renault "1.5 DCI" diesel engines. Renault's 1.5 DCI diesel engines are used in many other vehicles, primarily Renault ones (of course), but also many Dacias, some Nissans, etc.
The technical name of all 1.5 DCI engines is "K9K".
Beware that there are generally many editions and revisions of 1.5 DCI engines. The number suffix after the "K9K" name determines the edition/version of the engine.
The various editions and versions of 1.5 DCI engines are distinguished primarily by their power output (ranging from 48 kW to cca 81 kW). However, the configuration and models of engine peripherals like the turbocharger, intercooler, fuel injection system, emission control system etc. are highly dependent on the engine edition/version.
More information on 1.5 DCI engines is written in an article in global world Wikipedia.
  • The technical name of the older 48 kW DDiS engine is "K9K 700".
  • Main specifications: diesel, 1461 cm3 cubic capacity, power 48 kW / 65 PS, direct injection, common-rail, torque 160 Nm @ 2000 RPM, turbocharged, non-intercooled.
  • It conforms to Euro 3 emission specifications.
  • This (or very similar) engine is also used in some editions of Renault Clio II, Renault Kangoo and Dacia Logan.
  • On those vehicles, the engine can be recognized by having the same 48 kW of power, but the compatibility of every engine part, sensor and peripheral device against the engine used in DDiS Jimny may vary. Investigating all that would be a grand project!
  • This engine has a very troublesome fuel injection system, and therefore all vehicles with this engine should be avoided!
  • The technical name of the newer 63 kW DDiS engine is "K9K 266".
  • Main specifications: diesel, 1461 cm3 cubic capacity, power 63 kW / 86 PS, torque 200 Nm @ 1750 RPM, turbocharged, intercooled.
  • It conforms to Euro 4 emission specifications.
  • This (or very similar) engine is also used in Renault Clio III, Renault Megane II and III, Renault Modus, Dacia Sandero and Nissan Micra III.
  • On those vehicles, the engine can be recognized by having the same 63 kW of power, but the compatibility of every engine part, sensor and peripheral device against the engine used in DDiS Jimny may vary. Investigating all that would be a grand project!
  • The fuel injection system in this engine is different than in K9K 700 engine, and generally has no widespread issues.
Most suzuki's warehouses and distribution centers in Europe stock all parts for DDiS Jimnys, even all engine parts, normally like any other part, under Suzuki's catalogue numbers and with Suzuki badging on the packaging. It is logical to assume that they bought at least the engine parts either from Renault or from Renault's OEM suppliers.
However, most engine and engine peripherals' parts can also be bought either genuine from Renault or on the aftermarket. That is good news because Suzuki's prices are generally horrendously expensive (but not always though).
The main issue is that it's not easy to determine which Renault parts are the matching equivalents, because of so many variations of 1.5 DCI engines. The simplest way is to have your DDiS engine serviced by experienced Renault mechanics, who should be able to determine and obtain the matching Renault or aftermarket parts for your DDiS Jimny's engine.
You can of course do you own investigations and matching on the Internet.
Forum user Bosanek had personal experience with successfully using the following OEM Renault or aftermarket parts in his own DDiS 2nd gen. (type 6) Jimny:
DDiS engine parts used
Part description Suzuki P.N. Part actually used Alternatives Notes
Timing belt kit
(timing belt and timing belt tensioner)
? Genuine Renault
(P.N. 77 01 477 028)
Others available None
Accessory drive belt
(serpentine belt)
? Genuine Renault
(P.N. unknown)
Others available P.N. unknown because mechanic
obtained the part
Water pump ? Genuine Renault
(P.N. unknown)
obtained the part
Glow plug(s) ? SWAG 30 91 7979 Many others available None
Camshaft sensor ? Metzger 0903038 Many others available None
Crankshaft sensor ? Metzger 0902052 Many others available None
Inlet metering valve
(fuel pressure regulator)
for the high pressure fuel pump
? Delphi 9109-903 No other models or makes
appear to be compatible
Alternate P.N.s:
1. Delphi 28233373
2. Delphi 9307Z523B
Camshaft front oil seal ? Genuine Renault, P.N. unknown Others available P.N. unknown because mechanic
obtained the part
Coolant temperature sensor ? Metzger 0905159 Others available Acquired preventively
but not yet installed
Electrical generator pulley ? Iskra (if remembered correctly)
(P.N. unknown)
? P.N. unknown because electrician
obtained the part
Fuel filter 15410-84A51 1. Genuine Suzuki 15410-84A51
2. Mann WK 9008
3. Mahle/Knecht KL 404
Many others available The filter in Suzuki's
genuine packaging was in fact
Mahle/Knecht KL 404 - high quality
Air filter ? Japanparts FA-823S Many aftermarket brands available None
Oil filter ? Blue Print ADN12121 Many aftermarket brands available None
Bosanek also verified in practice that the oil sump on the DDiS K9K 266 engine is different than in similar K9K (1.5 DCI) engines found in Renault cars. The oil sump in DDiS engine was modified (probably on Suzuki's request) to provide better oil flow through the engine (and avoid engine's oil starvation) under significant vehicle inclinations, including significant side inclinations. This was smart thinking from Suzuki, but it also means that in case of a damaged engine oil sump, you will most probably have to hunt for a replacement one strictly from another DDiS Jimny (or from Suzuki). It is not known if this situation is the same with the oil sump in older DDiS K9K 700 engine.
Tips for care and maintenance of DDiS engines
Renault's DCI engines are not the most robust engines in the industry, and they should be driven with care. If done so, they typically return the same amount of care.
Important elements of care
  1. Do not drive off immediately after starting a cold engine. In the summer time, wait at least 10 seconds. In the winter time, wait at least 30 seconds, or at least a minute for freezing temperatures.
  2. Even if you restart a warm engine after a shorter pause, wait at least 10 seconds before driving off, so that the engine oil achieves good flow.
  3. Do not shut the engine off immediately after stopping, especially after high speed driving, driving uphill or driving off road (in short, under load)! Idle the engine for at least a minute after stopping in such situations, so that the turbocharger cools off through the flowing oil. Otherwise, turbocharger's bearings can be damaged. This is a standard issue with all turbocharged engines.
  4. Avoid "revving" the engine hard in any condition (above 3500 RPM). Preferably keep the engine RPMs under 3000 RPM. There isn't much benefit in "revving" a diesel engine in general, as their torque curve is biased much more around 2000 RPM range.
  5. Do not use high throttle in low engine RPMs (below cca 1500 RPM). This puts excessive load on the engine and the turbocharger. If RPMs drop that low, don't be lazy - change to lower gear and then apply the throttle.
  6. Use high quality engine oil and change it at least every 10 000 km (manual says every 15 000 km). For frequent off road driving, use oil changing intervals of 7000-8000 km.
  7. Change the air filter with each engine oil change. Don't skimp and just clean it!
  8. Do not use low quality diesel fuel! The fuel injection systems of DCI engines are quite sensitive and delicate, and low quality fuel can produce many headaches (intermittent annoying issues or even permanent and expensive damage).
  9. Avoid letting the fuel level in the fuel tank drop to the reserve. This way gum and deposits from the bottom of the fuel tank could get sucked into the delicate fuel distribution and injection system.
  10. Replace the fuel filter in regular intervals. It's a rather simple job. Manuals says every 45 000 km, but this highly depends on the fuel quality in your country. Many Eastern and South Eastern European countries are notorious for the presence of low quality fuels, so much that some vehicle manufacturers do not sell their diesel vehicles in such countries at all. In such circumstances, the fuel filter should be replaced every 30 000 km, preferably every 20 000 km. It's your choice!
  11. Use only high quality fuel filters. Proven high quality fuel filters for 2nd gen. (63 kw) DDiS Jimnys are Mahle/Knecht KL 404, Mann WK 9007, Valeo 587544, etc. There are other high quality brands of course.
  12. Have the EGR valve and turbocharger's connecting pipes cleaned of soot and other deposits in regular intervals (for example every 50 000 km at most).
  13. You might consider periodically using engine flushing chemicals to flush the engine when changing engine oils. A possibly recommended interval might be every 50 000 km. However, this is a somewhat controversial topic in general, so you should perform the final investigation about the risks of this procedure in general.
  14. You might consider periodically using fuel flushing chemicals to flush the fuel in the fuel tank, fuel piping and clean the fuel injectors. If high quality chemicals are used, there should not be any risk of side effects. Renault sells a "diesel fuel injection system treatment" chemical which is allegedly specifically made for their DCI engines. The best time to use fuel treatment chemicals is shortly before changing the fuel filter.
The procedure of using a fuel treatment chemical
  1. Buy the treatment chemical of your choice.
  2. Drive until the fuel tank is almost empty.
  3. Stop at your desired gas station.
  4. Pour the fuel treatment chemical in the fuel tank.
  5. Pour in diesel fuel until the fuel tank is half full (to achieve double density of chemical in the fuel).
  6. Drive hard in the following period until you almost empty the fuel tank. The best way is to drive on the motorway in 4th gear but at the same speed as you would normally drive in the 5th gear. For example, drive at 100 km/h in 4th gear continuously for at least 15 minutes. That will be around 3200 RPM and will both burn out any deposits in the engine and the exhaust (catalytic converter etc.) as well as pump high fuel flow through the fuel injection system.
  7. When you almost empty the fuel tank, pour in new diesel fuel normally and you're done.
  8. Replace the fuel filter.
Servicing DDiS engines
General tips
When doing regular periodic maintenance of your DDiS engine, or in the unfortunate event that you do have a problem with your DDiS engine, your best chance of repair would be to go to an experienced Renault mechanic. If they initially refuse to work on a non-Renault vehicle, try to persuade them to work on the engine only, and tell them that it's practically a standard Renault engine.
If the problem is so complicated that it requires accessing vehicle's ECU for performing diagnostics or changing computer settings, you will most probably have to go to a Suzuki authorized workshop because only Suzuki's genuine diagnostic devices can properly access all information and settings in DDiS Jimny's ECUs. Renault's diagnostic devices will probably recognize a generic OBD2 ECU with a rather limited information set available (that has at least been Bosanek's experience).
Issue with a 3-way coolant pipe on gen. 2 DDiS Jimnys
If you notice engine coolant leaks below the engine bay of your 2nd gen. DDiS Jimny (with 63 kW), you might have a common failure of one small nasty coolant system part.
There is a plastic 3-way pipe as a part of engine's cooling system and is known to wear out and start leaking after cca 50 000 - 80 000 km (your mileage may wary!). The pipe actually gets "eaten off" by the coolant.
The 3-way pipe is very hard to access, and is therefore a bit hard to determine as the source of the leak once the leak appears below the vehicle.
OEM P.N. is 17878-84A50.
Click on the pictures below to see a red arrow which points to the location of the 3-way pipe.
Technical differences between DDiS and petrol Jimnys
Note Icon.pngThe work on filling the tables below is still in the early stages! It should be complete probably in February-March 2017. So come again a bit later!
  • "Common" means that such a part is commonly shared between DDiS and at least one of petrol Jimny revisions - usually at least the same petrol revision ("type") as the DDiS revision ("type") - in third words, compatible with petrol vehicles which were in production at the time as the corresponding DDiS revision;
  • "Specific" means that a part is unique/specific only to DDiS Jimnys. It won't fit petrol Jimnys and vice versa. Therefore, you have to buy this part specifically for a DDiS Jimny (in the aftermarket if available, otherwise from Suzuki) or scavenge it from another DDiS Jimny. Also beware that some "DDiS specific" parts are compatible only with the 1st or the 2nd DDiS generation. Read the notes in the tables for details!
Also beware that Jimnys built by Santana in Spain (both petrol and diesel) might have some parts specific to them only! Spanish Jimny's VIN's begin with VSE....
Suspension parts
Suspension
Component Compatibility Checked in practice? Notes
Radius arms, front Common No None
Radius arms, rear Common No None
Radius arm bushings (all) Common No All radius arm to chassis bushings were improved in 2007
(just like in petrol Jimnys) to fight death wobble
Panhard rod, front Common No Common with LHD petrol Jimnys only
(all RHD Jimnys have a front panhard rod specific to them)
Panhard rod, rear Common No None
Panhard rod bushes, front Common No None
Panhard rod bushes, rear Common No None
Coil springs, front Specific No Stronger to cope with extra weight in the engine bay
DDiS P.N.: 41111-84A00 (per piece) - used by all DDiS Jimnys
Shock absorbers, front Specific No Stronger to cope with extra weight in the engine bay
DDiS P.N.: 41600-84A00 (per piece) - used by all DDiS Jimnys
Coil springs, rear Common No Common with LHD petrol Jimnys only
(all RHD Jimnys have rear springs specific to them)
Shock absorbers, rear Common No None
Stabilizer (anti roll) bar Specific Yes, on type 6 DDiS Bar diameter 28 mm
(significantly thicker than in petrol Jimnys)
DDiS P.N.: 42311-84A00 - used by all DDiS Jimnys
Stabilizer bar
bushing brackets
Specific Yes, on type 6 DDiS Larger to accommodate larger bushings
DDiS P.N.: 42415-84A00 - used by all DDiS Jimnys
Stabilizer bar
to chassis bushings
Specific Yes, on type 6 DDiS Inner diameter 28 mm, outer diameter also larger
DDiS P.N.: 42412-84A00 (per piece) - used by all DDiS Jimnys
Stabilizer bar to
axle "drop" link
Common No None
Wheel rims Common Yes, on type 6 DDiS None
Drivetrain parts
Drivetrain
Constant velocity
(CV) joint
Common Yes, on type 6 DDiS For all Jimnys: CV joints in type 5 and newer
are different than in type 4 and older
Kingpin Common Yes, on type 6 DDiS None
Kingpin bearing Common Yes, on type 6 DDiS None
Front wheel bearing Common Yes, on type 6 DDiS
Rear wheel bearing Common No None
Vacuum locking hub Common Yes, on type 6 DDiS For all Jimnys: Vacuum locking hubs in type 5 and newer
Seals (steering knuckle,
halfshaft, wheel bearing, etc.)
Front wheel hub casing Common Yes, on type 6 DDiS For all Jimnys: Wheel hub casings in type 5 and newer
Front axle casing Specific No Probably because of different coil spring seats
or shock absorber mounts
Used by all DDiS Jimnys
Rear axle casing Common No None
Axle differential
drain and filler plugs
Common Yes, on type 6 DDiS Common for both front and rear
Steering parts
Steering
Steering column assembly For 1st gen. DDiS:
Common except column itself and the cover
For 2nd gen. DDiS:
Common except the cover
No 1a. The column itself in petrol Jimnys in type 5 and newer
is different than in type 4 and older.
1b. The column in 2nd gen. DDiS matches the newer column from petrol Jimnys.
2. The difference in the cover (casing) might just be cosmetic
Steering box Specific No DDiS P.N.: 48600-84A80
Steering box pitman arm Specific No DDiS P.N.: 48671-84A80
Tie rod,
in front of the front axle
Common for Jimnys made in Japan
Specific for Santana Jimnys
No See note below
Tie rod,
behind the front axle
No See note below
Tie rod end,
left hand tread
No See note below
Tie rod end,
right hand tread
No See note below
Power steering pump,
pulleys and piping
Specific No None
Power steering oil tank Common No None
Engine and engine peripherals parts
Engine itself Specific (obviously!) No need None
Engine mounting bushes, front Specific No Two are used per engine
(left and right)
Engine mounting bush rear
("gearbox mount")
Specific for 1st gen. DDiS
Common for 2nd gen. DDiS
No One is used per engine
Engine cooling system Specific Yes, on type 6 DDiS The engine cooling system also differs between 1st and 2nd DDiS generation
Fuel injection system Specific Obvious The fuel injection system also differs between 1st and 2nd DDiS generation
Fuel filter Specific Yes, on type 6 DDiS The fuel filter also differs between 1st and 2nd DDiS generation
Air conditioning system Specific
Electrical generator Specific?
Electrical engine starter Specific?
Air filter and oil filter Specific
Sensors (camshaft, crankshaft,
oxygen, temperature, etc.)
Specific
Catalytic converter Specific?
Transmission parts
Transmission
Component Compatibility Notes
Front differential Specific?
Front halfaxle, left Common?
Front halfaxle, right Common?
Rear differential Specific?
Rear halfaxle, left Common?
Rear halfaxle, right Common?
Propeller shaft
from gearbox to transfer case
Common?
Propeller shaft
from transfer case to front axle
Common?
Propeller shaft
from transfer case to rear axle
Common?
Universal joint for propeller shafts Common
Transfer box casing Specific?
Transfer box gears
and components
Specific?
Gearbox casing Specific?
Gearbox gears
and components
Specific?
Front wheel vacuum locking hubs Common
Vacuum system for
operating front wheel hubs
Specific (partially)*
Transmission lever
(for older transfer boxes)
Common
Transmission buttons and electrics
(for newer transfer boxes)
Common
Body parts
Bodywork
Chassis Specific (front rails strengthened)
Bonnet Specific (has a bulge)
Engine bay internals Specific (different layout of engine peripherals)
All other body panels Common
Electrical parts
Electrical
ECU (computer) Specific
Instrument cluster Specific
Fuse and relay box
in the engine compartment
Specific
Fuse box under
the dash board
Overall wiring Partly specific
Lamps
(driving, turn, brake, interior, etc.)
Common
Fuel tank system parts
Fuel tank system
Fuel tank Specific?
Fuel tank intake piping Specific?
Fuel tank filler cap Specific
Other parts
Other
Cabin (pollen) filter Common Yes Example product is Blueprint ADK82502
Throttle pedal assembly Specific No None
Brake pedal assembly Common No None
Clutch pedal Common No None
Clutch pedal small back lever Specific No None
Brake system parts
The entire brake system (brake discs, brake pads, brake drums, brake shoes, calipers, cylinders, cables, piping, etc.) is the same as in petrol Jimnys.
However, bear in mind that (for all Jimnys) certain brake components differ in types 5 and newer from types 4 and older. Examples are brake discs and brake pads.
Notes on vacuum system for front wheel hubs
File:DDiS Jimny engine bay - vacuum valves - A01.jpg
Location of the vacuum valves and switches in the engine bay of a DDiS Jimny
In DDiS Jimnys, the vacuum system for the front wheel vacuum locking hubs is located in a different portion of the engine bay than in petrol Jimnys. It is much more accessible in DDiS Jimnys.
The vacuum is supplied directly by engine's vacuum pump (which itself is directly connected to the electrical generator), while in petrol Jimnys there is no vacuum pump at all. That same vacuum pump supplies some other engine peripheral systems as well.
There is no tank to store the vacuum. However, the valves and switches of the vacuum system, as well as the piping, are the same as in petrol Jimnys, except for some possible length differences in the piping. The piping scheme between the valves and the hubs are the same.
If you suspect that your vacuum system has issues, read the wiki article "Vacuum hubs - Checking and testing".
Notes on vehicle computer systems
The ECU (vehicle computer) is still Suzuki's despite the engine being Renault's. Suzuki adopted all engine sensors and electrics to be compatible with its ECU, and vice versa.
Therefore, all diagnostic devices (including Suzuki's genuine SDT tool of course) which read Suzuki's diagnostic protocols can normally and fully access all diagnostic information and settings.
On the other hand, Renault's diagnostic devices will (most likely) recognize the ECU as nothing more than another generic OBD2 unit, and the most that they would most likely be able to read is generic standard OBD2 data (which Suzuki intentionally made to be relatively scarce to force you to come to them for full diagnostic aid).
Page last edited on 27/02/2017 by user Bosanek
